HP Pavilion x2 10-n113dx Mainboard Replacement
    1. HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: step 1, image 1 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: step 1, image 2 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: step 1, image 3 of 3
      • Before starting, please turn off your laptop.
      • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
      Ask FixBot
    2. HP Pavilion x2 10-n113dx  Mainboard Replacement: step 2, image 1 of 2 HP Pavilion x2 10-n113dx  Mainboard Replacement: step 2, image 2 of 2
      • Gently lift and remove the display panel from the assembly.
      • Remove the translucent yellow tape that covers the battery connector on the mainboard.
      • The tape will be in the way for a future step.
      Ask FixBot
    3. HP Pavilion x2 10-n113dx  Mainboard Replacement: step 3, image 1 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: step 3, image 2 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: step 3, image 3 of 3
      • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
      • Carefully disconnect the white ribbon cable from the mainboard.
      Ask FixBot
    4. HP Pavilion x2 10-n113dx  Mainboard Replacement: step 4, image 1 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: step 4, image 2 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: step 4, image 3 of 3
      • Carefully disconnect the battery cable from its connector on the mainboard.
      Ask FixBot
    5. HP Pavilion x2 10-n113dx  Mainboard Replacement: step 5, image 1 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: step 5, image 2 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: step 5, image 3 of 3
      • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
      • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
      • Remove the battery from the device.
      Ask FixBot
    1. HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: step 6, image 1 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: step 6, image 2 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: step 6, image 3 of 3
      • To unscrew the mainboard use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws
      Ask FixBot
    2. HP Pavilion x2 10-n113dx  Mainboard Replacement: step 7, image 1 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: step 7, image 2 of 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: step 7, image 3 of 3
      • Remove mainboard.
      Ask FixBot
4 other people completed this guide.
David Zambrano
837 Reputation
5 Guides authored
USF Tampa, Team S13-G4, Boczar Fall 2017 Member of USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 Members
60 Guides authored
5 Guide Comments
Is this about the WiFi card? Because I cant see the SSD in any of your pictures.
Julian Lemmerich - Reply Share
So, where is the SSD? You’ve taken apart the whole logic board, but not evidence of any SSD module from your photos….
Matteo Repossi - Reply Share
It is not SSD drive, it is a motherboard
Da K - Reply Share
has anyone figured out where is the SSD (eMMC) by the way ?
Karantez Jegou - Reply Share
Do you happen to know how to reset the BIOS on this board if it does not boot?
Lewis Fields - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 43
All Time: 8,479
