HP Pavilion g7-1368dx Keyboard Replacement
    1. HP Pavilion g7-1368dx Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn the device over so that the lower case is facing up.
      • Slide the battery release latch. The battery will pop up.
      Ask FixBot
    2. HP Pavilion g7-1368dx Keyboard Replacement: step 2, image 1 of 1
      • Lift and remove the battery from its compartment.
      Ask FixBot
    1. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: step 3, image 1 of 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: step 3, image 2 of 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Loosen the two Phillips #1 screws that connect the service panel to the device.
      • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
      • Slide the service panel down and pull it up to remove.
      Ask FixBot
    2. HP Pavilion g7-1368dx Keyboard Replacement: step 4, image 1 of 1
      • Remove the one 7 mm Phillips #1 screw securing the keyboard to the device.
      Ask FixBot
    3. HP Pavilion g7-1368dx Keyboard Replacement: step 5, image 1 of 1
      • Flip over the device and open the screen.
      Ask FixBot
    4. HP Pavilion g7-1368dx Keyboard Replacement: step 6, image 1 of 2 HP Pavilion g7-1368dx Keyboard Replacement: step 6, image 2 of 2
      • Flip the keyboard over and locate the black ribbon cable that attaches the keyboard to the device.
      • Using a plastic opening tool, flip up the white tab on the zero insertion force connector.
      • Disconnect the ribbon cable by sliding it out of the ZIF connector.
      • Remove the keyboard.
      Ask FixBot
Kianna Young
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 572
