HP Pavilion g7-1365dx WLAN Module Replacement
    1. HP Pavilion g7-1365dx WLAN Module Replacement, Battery: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is powered off before removing the battery.
      • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
      • Push the switch above the battery towards the center of the laptop .
      Ask FixBot
    2. HP Pavilion g7-1365dx WLAN Module Replacement: step 2, image 1 of 1
      • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
      Ask FixBot
    1. HP Pavilion g7-1365dx WLAN Module Replacement, Service Door: step 3, image 1 of 2 HP Pavilion g7-1365dx WLAN Module Replacement, Service Door: step 3, image 2 of 2
      • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
      • Use the opening tool around the edges of the service door to loosen it and remove it.
      Ask FixBot
    1. HP Pavilion g7-1365dx WLAN Module Replacement, WLAN Module: step 4, image 1 of 1
      • Gently pull the black and gray coaxial connectors vertically up off of the module.
      • Make sure to remember which wire was connected to which terminal.
      Ask FixBot
    2. HP Pavilion g7-1365dx WLAN Module Replacement: step 5, image 1 of 1
      • Use a Phillips #00 screwdriver to take out the 4.7mm screw holding the module.
      • The module is on a spring and will pop out once the screw is taken out.
      Ask FixBot
    3. HP Pavilion g7-1365dx WLAN Module Replacement: step 6, image 1 of 1
      • Use your fingers to pull out the WLAN module as shown.
      Ask FixBot
Rafal Szmyd
193 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 65
All Time: 528
