Introduction
Go to step 1 ↓This guide will give step by step instructions on how to remove and replace a Memory Module in an HP Pavilion g7-1365dx. Use this guide if you're having issues with not enough RAM or a faulty RAM stick which could cause the laptop to be slow, frozen, or have no screen display.
Tools
Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
Push the switch above the battery towards the center of the laptop .
Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
Use the opening tool around the edges of the service door to loosen it and remove it.
