HP Pavilion g7-1330ca Battery Replacement
    1. HP Pavilion g7-1330ca Battery Replacement, Battery: step 1, image 1 of 1
      • Shut down the laptop and disconnect the charger from the laptop before beginning the repair.
      Ask FixBot
    2. HP Pavilion g7-1330ca Battery Replacement: step 2, image 1 of 1
      • Turn the laptop over so the bottom of the device is facing upward on a flat surface.
      Ask FixBot
    3. HP Pavilion g7-1330ca Battery Replacement: step 3, image 1 of 3 HP Pavilion g7-1330ca Battery Replacement: step 3, image 2 of 3 HP Pavilion g7-1330ca Battery Replacement: step 3, image 3 of 3
      • Unlock the Battery
      • Above the battery, push the battery release latch fully to the right. Continue pushing until you hear the battery release from the compartment.
      Ask FixBot
    4. HP Pavilion g7-1330ca Battery Replacement: step 4, image 1 of 3 HP Pavilion g7-1330ca Battery Replacement: step 4, image 2 of 3 HP Pavilion g7-1330ca Battery Replacement: step 4, image 3 of 3
      • Remove the battery from the compartment by gripping it with your thumb and index finger and gently lifting it out.
      • Avoid using excessive force to prevent puncturing or damaging the battery.
      Ask FixBot
    5. HP Pavilion g7-1330ca Battery Replacement: step 5, image 1 of 2 HP Pavilion g7-1330ca Battery Replacement: step 5, image 2 of 2
      • Identify the Battery Model
      • Check the left side of the battery and confirm that the model number is MU06.
      • If the battery appears swollen or punctured, stop the repair. Handle the battery with care and dispose of it at an approved battery recycling facility.
      Ask FixBot
    6. HP Pavilion g7-1330ca Battery Replacement: step 6, image 1 of 3 HP Pavilion g7-1330ca Battery Replacement: step 6, image 2 of 3 HP Pavilion g7-1330ca Battery Replacement: step 6, image 3 of 3
      • Install the replacement MU06 Notebook Battery by aligning it with the battery compartment and gently pressing it into place until you hear a click.
      • If the MU06 Notebook Battery is not available, the MU09 Notebook Battery is also compatible.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Chelsea
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 29
All Time: 136
