HP Pavilion g7-1150us RAM Replacement
    1. HP Pavilion g7-1150us RAM Replacement, Battery: step 1, image 1 of 2 HP Pavilion g7-1150us RAM Replacement, Battery: step 1, image 2 of 2
      • Slide the battery removal switch towards the center of the laptop until the battery pops out.
      Ask FixBot
    2. HP Pavilion g7-1150us RAM Replacement: step 2, image 1 of 1
      • Remove the battery from the computer.
      Ask FixBot
    1. HP Pavilion g7-1150us RAM Replacement, Surface Panel: step 3, image 1 of 1
      • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
      Ask FixBot
    2. HP Pavilion g7-1150us RAM Replacement: step 4, image 1 of 2 HP Pavilion g7-1150us RAM Replacement: step 4, image 2 of 2
      • Using the spudger, pry the surface panel off starting from the side where the battery was located.
      • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
      • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
      Ask FixBot
    3. HP Pavilion g7-1150us RAM Replacement: step 5, image 1 of 1
      • Lift the pried surface panel off of the computer.
      Ask FixBot
    1. HP Pavilion g7-1150us RAM Replacement, RAM: step 6, image 1 of 1
      • Push outwards on the two clips holding the RAM in place.
      Ask FixBot
    2. HP Pavilion g7-1150us RAM Replacement: step 7, image 1 of 2 HP Pavilion g7-1150us RAM Replacement: step 7, image 2 of 2
      • Slide the RAM out of its position in the opposite direction of the battery removal switch.
      Ask FixBot
Kyle Dinunno
401 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 64
All Time: 897
