HP Pavilion g6-2228tx RAM Replacement
    1. HP Pavilion g6-2228tx RAM Replacement, Battery: step 1, image 1 of 2 HP Pavilion g6-2228tx RAM Replacement, Battery: step 1, image 2 of 2
      • Push the battery latch to the left to release the battery.
      • Remove the battery from the device.
      Ask FixBot
    1. HP Pavilion g6-2228tx RAM Replacement, Hard Drive: step 2, image 1 of 2 HP Pavilion g6-2228tx RAM Replacement, Hard Drive: step 2, image 2 of 2
      • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
      Ask FixBot
    2. HP Pavilion g6-2228tx RAM Replacement: step 3, image 1 of 3 HP Pavilion g6-2228tx RAM Replacement: step 3, image 2 of 3 HP Pavilion g6-2228tx RAM Replacement: step 3, image 3 of 3
      • Place your hand on the cover and slide the cover down.
      • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
      Ask FixBot
    3. HP Pavilion g6-2228tx RAM Replacement: step 4, image 1 of 2 HP Pavilion g6-2228tx RAM Replacement: step 4, image 2 of 2
      • Place one finger on the right side of the hard drive.
      • Push the hard drive to the left and lift the hard drive up to remove it from the device.
      Ask FixBot
    4. HP Pavilion g6-2228tx RAM Replacement: step 5, image 1 of 2 HP Pavilion g6-2228tx RAM Replacement: step 5, image 2 of 2
      • Disconnect the connecting part by pulling the part to the right.
      • Remove the hard drive from the device.
      Ask FixBot
    1. HP Pavilion g6-2228tx RAM Replacement, RAM: step 6, image 1 of 2 HP Pavilion g6-2228tx RAM Replacement, RAM: step 6, image 2 of 2
      • The silver hinges holds the RAM in place.
      Ask FixBot
    2. HP Pavilion g6-2228tx RAM Replacement: step 7, image 1 of 2 HP Pavilion g6-2228tx RAM Replacement: step 7, image 2 of 2
      • Use two fingers to push both silver hinges outward to release the RAM.
      • The released RAM will pop up.
      Ask FixBot
    3. HP Pavilion g6-2228tx RAM Replacement: step 8, image 1 of 1
      • Pull the RAM stick to the left and remove it from the device.
      Ask FixBot
Hai Lin
446 Reputation
4 Guides authored
UC Davis, Team S4-G6, Lore Fall 2018 Member of UC Davis, Team S4-G6, Lore Fall 2018
UCD-LORE-F18S4G6
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 75
All Time: 1,198
