HP Pavilion g6-1b79dx Bottom Panel Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
Past 7 Days:
23
Past 30 Days:
101
All Time:
2,637
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the bottom panel is damaged or needs to be moved to reach another component of the laptop this is a guide to remove it.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. HP Pavilion g6-1b79dx Bottom Panel Replacement, Battery: step 1, image 1 of 1
      • Flip the computer so the bottom is facing up with the battery away from you.
      • Turn off the computer and disconnect the charger.
      Ask FixBot
    2. HP Pavilion g6-1b79dx Bottom Panel Replacement: step 2, image 1 of 2 HP Pavilion g6-1b79dx Bottom Panel Replacement: step 2, image 2 of 2
      • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
      Ask FixBot
    3. HP Pavilion g6-1b79dx Bottom Panel Replacement: step 3, image 1 of 2 HP Pavilion g6-1b79dx Bottom Panel Replacement: step 3, image 2 of 2
      • Lift the battery from its compartment away from the laptop.
      Ask FixBot
    1. HP Pavilion g6-1b79dx Bottom Panel Replacement, Bottom Panel: step 4, image 1 of 1
      • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
      • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
      Ask FixBot
    2. HP Pavilion g6-1b79dx Bottom Panel Replacement: step 5, image 1 of 1
      • Use the metal spudger all around the panel to pop it up from the base.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
      Ask FixBot
    3. HP Pavilion g6-1b79dx Bottom Panel Replacement: step 6, image 1 of 3 HP Pavilion g6-1b79dx Bottom Panel Replacement: step 6, image 2 of 3 HP Pavilion g6-1b79dx Bottom Panel Replacement: step 6, image 3 of 3
      • With your hands, lift the panel completely off the base of the laptop.
      Ask FixBot
2 other people completed this guide.
Rachel Gallegos
873 Reputation
5 Guides authored
Baylor, Team 10-12, Williams Fall 2015 Member of Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 101
All Time: 2,637
