Up to 20% off select tools
HP Pavilion dv9000 RAM Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
94
All Time:
4,394
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
After we have had a computer for a while, we notice that it starts to slow down. When a computer slows down, it could be caused by many issues. If the computer is an older model, the sluggish symptoms may be cured by upgrading the system's RAM. Finding and accessing the RAM can be difficult, but this guide ensures ease of access.
    1. HP Pavilion dv9000 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over to expose the bottom side.
      • Locate the battery removal switch next to the battery compartment
      • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
      Ask FixBot
    2. HP Pavilion dv9000 RAM Replacement, Battery Removal: step 2, image 1 of 2 HP Pavilion dv9000 RAM Replacement, Battery Removal: step 2, image 2 of 2
      • Slide the switch all the way to the left to release the battery. The battery should pop up.
      • Lift the battery out.
      Ask FixBot
    1. HP Pavilion dv9000 RAM Replacement, RAM: step 3, image 1 of 3 HP Pavilion dv9000 RAM Replacement, RAM: step 3, image 2 of 3 HP Pavilion dv9000 RAM Replacement, RAM: step 3, image 3 of 3
      • Locate the middle plastic cover on the bottom of the laptop.
      • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
      • Lift and remove the plastic cover.
      Ask FixBot
    2. HP Pavilion dv9000 RAM Replacement: step 4, image 1 of 3 HP Pavilion dv9000 RAM Replacement: step 4, image 2 of 3 HP Pavilion dv9000 RAM Replacement: step 4, image 3 of 3
      • Locate the RAM card and the metal tabs on either side of it.
      • Press both tabs away from the RAM card to release it. The card should flip up towards you.
      • Carefully lift the RAM card out.
      Ask FixBot
Author
with
Erik Hoffnagle
807 Reputation
3 Guides authored
Cal Poly, Team 10-32, Maness Winter 2014 Member of Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 94
All Time: 4,394
