HP Pavilion dv9000 Keyboard Replacement
    1. HP Pavilion dv9000 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over to expose the bottom side.
      • Locate the battery removal switch next to the battery compartment
      • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
      Ask FixBot
    2. HP Pavilion dv9000 Keyboard Replacement, Battery Removal: step 2, image 1 of 2 HP Pavilion dv9000 Keyboard Replacement, Battery Removal: step 2, image 2 of 2
      • Slide the switch all the way to the left to release the battery. The battery should pop up.
      • Lift the battery out.
      Ask FixBot
    1. HP Pavilion dv9000 Keyboard Replacement, Keyboard: step 3, image 1 of 2 HP Pavilion dv9000 Keyboard Replacement, Keyboard: step 3, image 2 of 2
      • Remove the six 5 mm screws in the battery compartment using Phillips #1 screwdriver.
      • Remove the 7mm keyboard screw located towards the center of the laptop with a Phillips #1 screwdriver.
      Ask FixBot
    2. HP Pavilion dv9000 Keyboard Replacement: step 4, image 1 of 1
      • Flip the laptop over and open the lid.
      • Lift out the plastic panel containing the power button and flip it over.
      • Be careful, the panel is still attached by a small ribbon cable.
      Ask FixBot
    3. HP Pavilion dv9000 Keyboard Replacement: step 5, image 1 of 3 HP Pavilion dv9000 Keyboard Replacement: step 5, image 2 of 3 HP Pavilion dv9000 Keyboard Replacement: step 5, image 3 of 3
      • Locate the ribbon cable attached to the underside of the plastic panel.
      • Using a spudger, unplug the ribbon cable by pushing the brown tab away from circuit board and sliding the ribbon out with your hand.
      • Set the plastic panel aside.
      Ask FixBot
    4. HP Pavilion dv9000 Keyboard Replacement: step 6, image 1 of 3 HP Pavilion dv9000 Keyboard Replacement: step 6, image 2 of 3 HP Pavilion dv9000 Keyboard Replacement: step 6, image 3 of 3
      • Using a Phillips #1 screwdriver, remove the three 5mm screws holding the keyboard in place.
      • Carefully lift the keyboard up (no more than a few cm) and slide it forward, towards the laptops monitor to reveal another larger ribbon cable.
      • Be extremely careful as the keyboard is still attached to the computer by the larger ribbon cable.
      Ask FixBot
    5. HP Pavilion dv9000 Keyboard Replacement: step 7, image 1 of 3 HP Pavilion dv9000 Keyboard Replacement: step 7, image 2 of 3 HP Pavilion dv9000 Keyboard Replacement: step 7, image 3 of 3
      • Use a spudger to push the black tab forward and slide it away from the white connector.
      • Gently pull the ribbon cable from the connector housing.
      • Remove the keyboard.
      Ask FixBot
Erik Hoffnagle
807 Reputation
3 Guides authored
Cal Poly, Team 10-32, Maness Winter 2014 Member of Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Members
72 Guides authored
1 Guide Comment
Please I have a problem with my hp laptop the keyboard and there is noise on it, repair it automatic. thanks you
Clement Glah - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 109
All Time: 3,948
