HP Pavilion dv9000 Hard Drive Replacement
Views: 10K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
113
All Time:
10,027
Comments: 4
4 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In an age where files expand to huge sizes, it becomes necessary to have a large storage medium. Replacing a hard drive could be a challenging task, but this guide clarifies all potential issues.
Tools
    1. HP Pavilion dv9000 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over to expose the bottom side.
      • Locate the battery removal switch next to the battery compartment
      • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
      Ask FixBot
    2. HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: step 2, image 1 of 2 HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: step 2, image 2 of 2
      • Slide the switch all the way to the left to release the battery. The battery should pop up.
      • Lift the battery out.
      Ask FixBot
    1. HP Pavilion dv9000 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • There are two hard drive bays.
      • Hard drive bay 1 is in the lower right corner.
      • Hard drive bay 2 is in the lower left corner.
      Ask FixBot
    2. HP Pavilion dv9000 Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion dv9000 Hard Drive Replacement: step 4, image 2 of 2
      • To remove hard drive 1 from bay 1
      • Using a Phillips #1 screwdriver, remove the two 5 mm screws that hold the bay 1 cover in place.
      • The screws should remain in the cover.
      Ask FixBot
    3. HP Pavilion dv9000 Hard Drive Replacement: step 5, image 1 of 2 HP Pavilion dv9000 Hard Drive Replacement: step 5, image 2 of 2
      • After removing the two cover screws, lift and slide the cover out of position to access the hard drive.
      • Grab the clear plastic pull tab on top of the hard drive to lift the hard drive from the laptop.
      Ask FixBot
    4. HP Pavilion dv9000 Hard Drive Replacement: step 6, image 1 of 3 HP Pavilion dv9000 Hard Drive Replacement: step 6, image 2 of 3 HP Pavilion dv9000 Hard Drive Replacement: step 6, image 3 of 3
      • To remove hard drive 2 from bay 2.
      • Most laptops don't have a second hard drive. If yours does not, then proceed to the next step.
      • Using a Phillips #1 screwdriver remove the two 5 mm screws that hold the bay 2 cover in place.
      • Grab the clear plastic pull tab on top of the hard drive, and lift the hard drive from the laptop.
      Ask FixBot
    5. HP Pavilion dv9000 Hard Drive Replacement: step 7, image 1 of 3 HP Pavilion dv9000 Hard Drive Replacement: step 7, image 2 of 3 HP Pavilion dv9000 Hard Drive Replacement: step 7, image 3 of 3
      • After the hard drive has been removed from the laptop, it must then be removed from its bracket.
      • Start by gently pulling the HP hard drive adapter from the end of the hard drive.
      • Using a Phillips #1 screwdriver, remove the four 3 mm bracketing screws on both sides of the hard drive bracket (2 per side) .
      • Lift the hard drive from its metal bracket.
      • Be careful not to touch the green underside as this may damage the hard drive.
      Ask FixBot
9 other people completed this guide.
Robby Cabri
184 Reputation
1 Guide authored
Cal Poly, Team 10-32, Maness Winter 2014 Member of Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Members
72 Guides authored
4 Guide Comments
Hello. In step 7 of the above, what is the name/part number/ size etc of the adapter/connector please ? I need one urgently.
Thanks.
freeflyshannon - Reply Share
yes that would be very helpfull because the new SSdrive I have will not fit even though is is the same size. I think I need some sort of an adaptor as you say.
Stephen Cox - Reply Share
For modern SATA SSDs, the typical form factor is 7.5mm. The standard for laptop HDDs is 9.5mm. You will need to buy a plastic spacer in order to properly mount the drive inside your computer.
Michael - Reply Share
thanks for the help
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 113
All Time: 10,027
