HP Pavilion dv9000 Battery Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
6
Past 7 Days:
30
Past 30 Days:
105
All Time:
3,916
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Often after many uses, a laptops battery will no longer hold its charge. This is the time to replace it. In this laptop, the battery is easy to remove and replace.
    1. HP Pavilion dv9000 Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over to expose the bottom side.
      • Locate the battery removal switch next to the battery compartment
      • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
      Ask FixBot
    2. HP Pavilion dv9000 Battery Replacement, Battery Removal: step 2, image 1 of 2 HP Pavilion dv9000 Battery Replacement, Battery Removal: step 2, image 2 of 2
      • Slide the switch all the way to the left to release the battery. The battery should pop up.
      • Lift the battery out.
      Ask FixBot
5 other people completed this guide.
Michael
386 Reputation
2 Guides authored
Cal Poly, Team 10-32, Maness Winter 2014 Member of Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 105
All Time: 3,916
