HP Pavilion dv7t-7000 RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
66
All Time:
561
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This is a RAM replacement for HP Pavilion dv7t-7000.
Tools
    1. HP Pavilion dv7t-7000 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the computer off and disconnect if from all power sources.
      Ask FixBot
    2. HP Pavilion dv7t-7000 RAM Replacement: step 2, image 1 of 1
      • Slide the battery release switch to the left.
      Ask FixBot
    3. HP Pavilion dv7t-7000 RAM Replacement: step 3, image 1 of 1
      • Hold the release switch all of the way to the left and your other hand to pull the battery out.
      Ask FixBot
    1. HP Pavilion dv7t-7000 RAM Replacement, Back Panel: step 4, image 1 of 1
      • Unscrew the single Phillips #00 screw.
      • Screw will not come out, it is connected to the panel
      Ask FixBot
    2. HP Pavilion dv7t-7000 RAM Replacement: step 5, image 1 of 2 HP Pavilion dv7t-7000 RAM Replacement: step 5, image 2 of 2
      • Remove service hatch by sliding away from the computer and lifting up.
      Ask FixBot
    1. HP Pavilion dv7t-7000 RAM Replacement, RAM: step 6, image 1 of 2 HP Pavilion dv7t-7000 RAM Replacement, RAM: step 6, image 2 of 2
      • Push the retraining springs away from the RAM at the same time to unlock the RAM.
      Ask FixBot
    2. HP Pavilion dv7t-7000 RAM Replacement: step 7, image 1 of 2 HP Pavilion dv7t-7000 RAM Replacement: step 7, image 2 of 2
      • Pull the RAM out.
      • Follow the same procedure for the additional RAM.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 66
All Time: 561
