HP Pavilion dv7t-7000 Keyboard Replacement
  1. HP Pavilion dv7t-7000 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn the computer off and disconnect if from all power sources.
    Ask FixBot
  2. HP Pavilion dv7t-7000 Keyboard Replacement: step 2, image 1 of 1
    • Slide the battery release switch to the left.
    Ask FixBot
  3. HP Pavilion dv7t-7000 Keyboard Replacement: step 3, image 1 of 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
    Ask FixBot
  4. HP Pavilion dv7t-7000 Keyboard Replacement, Back Panel: step 4, image 1 of 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
    Ask FixBot
  5. HP Pavilion dv7t-7000 Keyboard Replacement: step 5, image 1 of 2 HP Pavilion dv7t-7000 Keyboard Replacement: step 5, image 2 of 2
    • Remove service hatch by sliding away from the computer and lifting up.
    Ask FixBot
  6. HP Pavilion dv7t-7000 Keyboard Replacement, Keyboard: step 6, image 1 of 2 HP Pavilion dv7t-7000 Keyboard Replacement, Keyboard: step 6, image 2 of 2
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
    Ask FixBot
  7. HP Pavilion dv7t-7000 Keyboard Replacement: step 7, image 1 of 3 HP Pavilion dv7t-7000 Keyboard Replacement: step 7, image 2 of 3 HP Pavilion dv7t-7000 Keyboard Replacement: step 7, image 3 of 3
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
    Ask FixBot
  8. HP Pavilion dv7t-7000 Keyboard Replacement: step 8, image 1 of 1
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 853
