HP Pavilion dv7-4285dx Keyboard Replacement
    1. HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: step 1, image 1 of 2 HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: step 1, image 2 of 2
      • Slide the battery release switch to the left. The battery pack will then subsequently release.
      Ask FixBot
    2. HP Pavilion dv7-4285dx Keyboard  Replacement: step 2, image 1 of 1
      • Remove the battery pack from the socket.
      Ask FixBot
    1. HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: step 3, image 1 of 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: step 3, image 2 of 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: step 3, image 3 of 3
      • Unscrew the 5 black plate screws using a Ph#0 screwdriver.
      • During the removal process, the back plate will retain the 5 back plate screws.
      • Use a metal spudger to carefully remove back plate.
      Ask FixBot
    2. HP Pavilion dv7-4285dx Keyboard  Replacement: step 4, image 1 of 1
      • Unscrew the 7.2mm screws using a Ph#0 screwdriver.
      Ask FixBot
    3. HP Pavilion dv7-4285dx Keyboard  Replacement: step 5, image 1 of 2 HP Pavilion dv7-4285dx Keyboard  Replacement: step 5, image 2 of 2
      • Push the keyboard release switch using the metal spudger.
      Ask FixBot
    4. HP Pavilion dv7-4285dx Keyboard  Replacement: step 6, image 1 of 2 HP Pavilion dv7-4285dx Keyboard  Replacement: step 6, image 2 of 2
      • Lift up keyboard from its resting position.
      Ask FixBot
    5. HP Pavilion dv7-4285dx Keyboard  Replacement: step 7, image 1 of 3 HP Pavilion dv7-4285dx Keyboard  Replacement: step 7, image 2 of 3 HP Pavilion dv7-4285dx Keyboard  Replacement: step 7, image 3 of 3
      • Lift up black tab holding ribbon cable.
      • Remove ribbon cable from motherboard.
      Ask FixBot
    6. HP Pavilion dv7-4285dx Keyboard  Replacement: step 8, image 1 of 1
      • Remove keyboard.
      Ask FixBot
Austin Sandel
363 Reputation
3 Guides authored
IUPUI, Team S1-G2, Baechle Fall 2018 Member of IUPUI, Team S1-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 75
All Time: 926
