HP Pavilion dv7-3065dx RAM Replacement
    1. HP Pavilion dv7-3065dx RAM Replacement, Battery: step 1, image 1 of 2 HP Pavilion dv7-3065dx RAM Replacement, Battery: step 1, image 2 of 2
      • Turn off the device before removing the battery.
      • Place the laptop upside down on a flat surface so that the bottom is facing up.
      • The battery is the long rectangle above the latch.
      Ask FixBot
    2. HP Pavilion dv7-3065dx RAM Replacement: step 2, image 1 of 1
      • Slide the battery latch to the left to release the battery.
      Ask FixBot
    3. HP Pavilion dv7-3065dx RAM Replacement: step 3, image 1 of 2 HP Pavilion dv7-3065dx RAM Replacement: step 3, image 2 of 2
      • Carefully pull out the battery while holding the latch to the open position with your finger.
      Ask FixBot
    1. HP Pavilion dv7-3065dx RAM Replacement, RAM: step 4, image 1 of 1
      • Remove the four circled screws using a #1 philips head screwdriver
      • Note: Be sure to leave the screws in the pannel
      • Pry off cover and place to the side.
      Ask FixBot
    2. HP Pavilion dv7-3065dx RAM Replacement: step 5, image 1 of 1
      • The RAM modules will be found on the right side of the access panel
      • CAUTION - The RAM modules are sensitive to electrostatic discharge. It is recommended to wear an anti static bracelet while handling the RAM.
      Ask FixBot
    3. HP Pavilion dv7-3065dx RAM Replacement: step 6, image 1 of 2 HP Pavilion dv7-3065dx RAM Replacement: step 6, image 2 of 2
      • To remove RAM modules, pry metal tabs out of the modules, and pull ram out (Starting from the top RAM module).
      • Note: The RAM Modules pop out away from the motherboard. In order to replace them, slot the gold plated end into the terminal and push down towards the motherboard.
      Ask FixBot
3 other people completed this guide.
Jonathan Winkler
161 Reputation
1 Guide authored
Ohio State, Team 1-5, Wilder Spring 2017 Member of Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 38
Past 30 Days: 129
All Time: 1,977
