HP Pavilion dv7-3065dx Keyboard Replacement
  1. HP Pavilion dv7-3065dx Keyboard Replacement, Battery: step 1, image 1 of 2 HP Pavilion dv7-3065dx Keyboard Replacement, Battery: step 1, image 2 of 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
    Ask FixBot
  2. HP Pavilion dv7-3065dx Keyboard Replacement: step 2, image 1 of 1
    • Slide the battery latch to the left to release the battery.
    Ask FixBot
  3. HP Pavilion dv7-3065dx Keyboard Replacement: step 3, image 1 of 2 HP Pavilion dv7-3065dx Keyboard Replacement: step 3, image 2 of 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
    Ask FixBot
  4. HP Pavilion dv7-3065dx Keyboard Replacement, Hard Drive: step 4, image 1 of 1
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
    Ask FixBot
  5. HP Pavilion dv7-3065dx Keyboard Replacement: step 5, image 1 of 1
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    Ask FixBot
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    Ask FixBot
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    Ask FixBot
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    Ask FixBot
    • Lift and remove the hard drive from the metal surrounding its perimeter.
    Ask FixBot
  6. HP Pavilion dv7-3065dx Keyboard Replacement, Keyboard: step 10, image 1 of 1
    • Locate these seven screws that fasten the keyboard and switch cover to the computer.
    • Remove these screws
    Ask FixBot
  7. HP Pavilion dv7-3065dx Keyboard Replacement: step 11, image 1 of 1
    • Flip over the computer to the upright position and locate the switch cover.
    • Carefully pry the switch cover up until it detaches from the computer.
    • The switch cover is held in with plastic clips. They may break if they are removed too forcefully.
    Ask FixBot
  8. HP Pavilion dv7-3065dx Keyboard Replacement: step 12, image 1 of 1
    • Raise the switch cover to expose the speaker assembly.
    • Carefully detach the ribbon cables from the speaker assembly.
    • Locate and remove these four screws from the switch cover.
    Ask FixBot
  9. HP Pavilion dv7-3065dx Keyboard Replacement: step 13, image 1 of 2 HP Pavilion dv7-3065dx Keyboard Replacement: step 13, image 2 of 2
    • Locate and remove the screws that hold the keyboard to the computer.
    • Lift the keyboard up to expose the keyboard connector.
    • The keyboard connector is the small cord located near the screen of the computer.
    Ask FixBot
  10. HP Pavilion dv7-3065dx Keyboard Replacement: step 14, image 1 of 2 HP Pavilion dv7-3065dx Keyboard Replacement: step 14, image 2 of 2
    • Disconnect the keyboard connector by unhinging the blue plastic clips and gently pulling the cord.
    • The keyboard can now be removed from the computer.
    Ask FixBot
2 other people completed this guide.
Nicholas Moore
302 Reputation
2 Guides authored
Ohio State, Team 1-5, Wilder Spring 2017 Member of Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 47
All Time: 2,278
