HP Pavilion dv7-1285dx RAM Replacement
    1. HP Pavilion dv7-1285dx RAM Replacement, Battery: step 1, image 1 of 1
      • Ensure the device is powered down and unplugged.
      • Turn the device upside down with the battery compartment facing you.
      • Slide the black slider to the right and lift the battery out of its compartment.
      Ask FixBot
    1. HP Pavilion dv7-1285dx RAM Replacement, Back Plate: step 2, image 1 of 1
      • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
      • These screws do not completely detach from the device when unscrewed.
      Ask FixBot
    2. HP Pavilion dv7-1285dx RAM Replacement: step 3, image 1 of 2 HP Pavilion dv7-1285dx RAM Replacement: step 3, image 2 of 2
      • Use the plastic opening tool to lift up the back plate and set it aside.
      Ask FixBot
    1. HP Pavilion dv7-1285dx RAM Replacement, RAM: step 4, image 1 of 1
      • Rotate the device 90 degrees to the left.
      Ask FixBot
    2. HP Pavilion dv7-1285dx RAM Replacement: step 5, image 1 of 3 HP Pavilion dv7-1285dx RAM Replacement: step 5, image 2 of 3 HP Pavilion dv7-1285dx RAM Replacement: step 5, image 3 of 3
      • Locate the grey clips on the side of the RAM and pull the grey clips away from the RAM using the plastic opening tool.
      Ask FixBot
    3. HP Pavilion dv7-1285dx RAM Replacement: step 6, image 1 of 3 HP Pavilion dv7-1285dx RAM Replacement: step 6, image 2 of 3 HP Pavilion dv7-1285dx RAM Replacement: step 6, image 3 of 3
      • Unplug the RAM.
      • Repeat step 6 to remove the second piece of RAM.
      Ask FixBot
    4. HP Pavilion dv7-1285dx RAM Replacement: step 7, image 1 of 2 HP Pavilion dv7-1285dx RAM Replacement: step 7, image 2 of 2
      • These steps are important in the replacement of the RAM, they will assist in ensuring the device is not damaged.
      • Align the notch in the new RAM with the peg on the plug
      • Ensure the RAM is fully inserted into the plug at a 45 degree angle such that the notch of the RAM lines up with the peg on the plug
      Ask FixBot
    5. HP Pavilion dv7-1285dx RAM Replacement: step 8, image 1 of 2 HP Pavilion dv7-1285dx RAM Replacement: step 8, image 2 of 2
      • Push down gently on the RAM until the grey clips click.
      • Repeat steps 7 and 8 to replace the second piece of RAM.
      Ask FixBot
2 other people completed this guide.
Jesse Quisido
513 Reputation
3 Guides authored
Cal Poly, Team 12-34, Maness Spring 2014 Member of Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 99
All Time: 1,545
