HP Pavilion dv7-1285dx Keyboard Replacement
    1. HP Pavilion dv7-1285dx Keyboard Replacement, Battery: step 1, image 1 of 1
      • Ensure the device is powered down and unplugged.
      • Turn the device upside down with the battery compartment facing you.
      • Slide the black slider to the right and lift the battery out of its compartment.
      Ask FixBot
    1. HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: step 2, image 1 of 2 HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: step 2, image 2 of 2
      • Using a Phillips Screwdriver, remove the four Phillips M25x3.0 head screws.
      Ask FixBot
    2. HP Pavilion dv7-1285dx Keyboard Replacement: step 3, image 1 of 2 HP Pavilion dv7-1285dx Keyboard Replacement: step 3, image 2 of 2
      • Using a plastic opening tool on both the left and right sides to remove the upper portion of the top plate.
      • Orient the device such that it’s partially opened (a little less than a 45 degree angle) and the hinge faces up.
      Ask FixBot
    3. HP Pavilion dv7-1285dx Keyboard Replacement: step 4, image 1 of 2 HP Pavilion dv7-1285dx Keyboard Replacement: step 4, image 2 of 2
      • Orient the laptop so the screen is open and facing you.
      • Grasp the top plate near the hinge and pull up.
      • This should expose a white ribbon cable.
      Ask FixBot
    4. HP Pavilion dv7-1285dx Keyboard Replacement: step 5, image 1 of 2 HP Pavilion dv7-1285dx Keyboard Replacement: step 5, image 2 of 2
      • Locate the dark grey slide on the sides of the ribbon cable plug.
      • Using the plastic opening tool, push both sides of the dark gray slide towards the screen of the computer.
      • Unplug the ribbon cable and set the top plate aside.
      Ask FixBot
    5. HP Pavilion dv7-1285dx Keyboard Replacement: step 6, image 1 of 2 HP Pavilion dv7-1285dx Keyboard Replacement: step 6, image 2 of 2
      • Locate the four Phillips M2.0x2 head screws at the top of the keyboard and remove them.
      • Gently lift the keyboard up from the screen side and pull the keyboard towards the screen.
      Ask FixBot
    6. HP Pavilion dv7-1285dx Keyboard Replacement: step 7, image 1 of 3 HP Pavilion dv7-1285dx Keyboard Replacement: step 7, image 2 of 3 HP Pavilion dv7-1285dx Keyboard Replacement: step 7, image 3 of 3
      • Locate the black ribbon cable attaching the keyboard to the computer.
      • Find the grey slides on the side of the ribbon cable plug.
      • Use the plastic opening tool to move the grey slides toward the screen.
      • Unplug the black ribbon cable.
      • Remove the keyboard.
      Ask FixBot
2 other people completed this guide.
Jesse Quisido
513 Reputation
3 Guides authored
Cal Poly, Team 12-34, Maness Spring 2014 Member of Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 105
All Time: 4,376
