HP Pavilion dv7-1285dx Back Plate Replacement
    1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: step 1, image 1 of 1
      • Ensure the device is powered down and unplugged.
      • Turn the device upside down with the battery compartment facing you.
      • Slide the black slider to the right and lift the battery out of its compartment.
      Ask FixBot
    1. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: step 2, image 1 of 1
      • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
      • These screws do not completely detach from the device when unscrewed.
      Ask FixBot
    2. HP Pavilion dv7-1285dx Back Plate Replacement: step 3, image 1 of 2 HP Pavilion dv7-1285dx Back Plate Replacement: step 3, image 2 of 2
      • Use the plastic opening tool to lift up the back plate and set it aside.
      Ask FixBot
Chris Apple
242 Reputation
2 Guides authored
Cal Poly, Team 12-34, Maness Spring 2014 Member of Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Members
74 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 1,835
