HP Pavilion dv6500 RAM Card Replacement
    1. HP Pavilion dv6500 RAM Card Replacement, Battery: step 1, image 1 of 1
      • Flip computer face down.
      Ask FixBot
    2. HP Pavilion dv6500 RAM Card Replacement: step 2, image 1 of 1
      • Remove the battery by sliding the button to the side.
      • Be careful if the battery is leaking or appears punctured in anyway. Battery acid is harmful and may cause burns.
      Ask FixBot
    1. HP Pavilion dv6500 RAM Card Replacement, Back Panel: step 3, image 1 of 1
      • Remove fifteen 7.0mm PH0 screws.
      • Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
      Ask FixBot
    1. HP Pavilion dv6500 RAM Card Replacement, RAM Card: step 4, image 1 of 3 HP Pavilion dv6500 RAM Card Replacement, RAM Card: step 4, image 2 of 3 HP Pavilion dv6500 RAM Card Replacement, RAM Card: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Using your fingers or thin non metallic tweezers, pull the 2 silver levers on either side of the RAM card outward to until the ends pop up.
      • Slide the RAM cards out of their sockets.
      Ask FixBot
4 other people completed this guide.
Andrew
392 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Catania Fall 2016 Member of UMass Dartmouth, Team 1-6, Catania Fall 2016
UMASSD-CATANIA-F16S1G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 105
All Time: 2,823
