HP Pavilion dv6000 Wireless Card Replacement
    1. HP Pavilion dv6000 Wireless Card Replacement, Wireless Card: step 1, image 1 of 1
      • Lay the laptop on a flat surface, battery side up.
      • Remove the two screws securing the RAM shield to the lower case.
      • The screws will remain captive within the shield.
      • Lift and remove the RAM shield up from the lower case.
      Ask FixBot
    2. HP Pavilion dv6000 Wireless Card Replacement: step 2, image 1 of 2 HP Pavilion dv6000 Wireless Card Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card.
      • Be careful to pull on the contacts and not the wires. The crimps used to hold them to the wires are delicate.
      Ask FixBot
    3. HP Pavilion dv6000 Wireless Card Replacement: step 3, image 1 of 1
      • Remove the two 3.7 mm Phillips screws securing the wireless card to the motherboard.
      • Upon removing the Phillips screws that secures the wireless card to the motherboard, the wireless card board should pop up from its top side.
      • Grasp the wireless card and pull it straight out of its socket on the motherboard.
      Ask FixBot
    4. HP Pavilion dv6000 Wireless Card Replacement: step 4, image 1 of 1
      • Wireless card remains.
      Ask FixBot
5 other people completed this guide.
Ben Hirsch
3,877 Reputation
10 Guides authored
Cal Poly, Team 21-33, Regan Fall 2010 Member of Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 111
All Time: 27,496
