HP Pavilion dv6000 Optical Drive Replacement
    1. HP Pavilion dv6000 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
      • Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
      • Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
      Ask FixBot
    2. HP Pavilion dv6000 Optical Drive Replacement: step 2, image 1 of 1
      • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
      • The tray will partially pop out of the laptop.
      • Firmly pull the drive straight away from the laptop.
      • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
      • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
      Ask FixBot
6 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 97
All Time: 8,865
