HP Pavilion dv6000 Hard Drive Replacement
    1. HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Remove the two screws from the hard drive shield and lift it off starting at the right side. The screws will remain in the shield.
      Ask FixBot
    2. HP Pavilion dv6000 Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion dv6000 Hard Drive Replacement: step 2, image 2 of 2
      • Pull the plastic tab attached to the hard drive. The hard drive lifts right out. Pull gently so you don't damage the contacts.
      Ask FixBot
    3. HP Pavilion dv6000 Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion dv6000 Hard Drive Replacement: step 3, image 2 of 2
      • Now you have your hard drive out!
      Ask FixBot
    4. HP Pavilion dv6000 Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion dv6000 Hard Drive Replacement: step 4, image 2 of 2
      • Gently pull forward the HP adapter from the top of the hard drive.
      • Insert the adapter onto the new SATA hard drive, to be replaced in the laptop.
      Ask FixBot
20 other people completed this guide.
Ben Hirsch
3,877 Reputation
10 Guides authored
Cal Poly, Team 21-33, Regan Fall 2010 Member of Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Members
120 Guides authored
2 Guide Comments
thanks for your help
moyguens - Reply Share
I was scratching my head when I recvd the new hd w/out the adapter... LOL! thanks
gilaraujog - Reply Share
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 157
All Time: 43,066
