Up to 20% off select tools
HP Pavilion dv6000 Camera Replacement
Views: 11K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
89
All Time:
10,856
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the camera on your HP Pavilion dv6000 needs to be repaired, follow this guide.
    1. HP Pavilion dv6000 Camera Replacement, Camera: step 1, image 1 of 2 HP Pavilion dv6000 Camera Replacement, Camera: step 1, image 2 of 2
      • Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
      • If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
      • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
      Ask FixBot
    2. HP Pavilion dv6000 Camera Replacement: step 2, image 1 of 3 HP Pavilion dv6000 Camera Replacement: step 2, image 2 of 3 HP Pavilion dv6000 Camera Replacement: step 2, image 3 of 3
      • Press the tabs in on the sides of the screen and pop the plastic covering off.
      • The edges of the LCD screen are very sharp. Take care to not cut your fingers!
      Ask FixBot
    3. HP Pavilion dv6000 Camera Replacement: step 3, image 1 of 1
      • Lift the screen out of the casing at the top near the camera.
      • Take care to not snap the plastic casing! It is brittle and still attached to the bottom of the screen.
      Ask FixBot
    4. HP Pavilion dv6000 Camera Replacement: step 4, image 1 of 1
      • Gently remove the main cable from the camera.
      Ask FixBot
    5. HP Pavilion dv6000 Camera Replacement: step 5, image 1 of 2 HP Pavilion dv6000 Camera Replacement: step 5, image 2 of 2
      • There are three clasps holding the camera down. Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings).
      • The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
      Ask FixBot
    6. HP Pavilion dv6000 Camera Replacement: step 6, image 1 of 1
      • Remove the camera unit from the laptop and you are done!
      Ask FixBot
3 other people completed this guide.
Author
with
Ben Hirsch
3,877 Reputation
10 Guides authored
Cal Poly, Team 21-33, Regan Fall 2010 Member of Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 89
All Time: 10,856
