HP Pavilion dv6-2158nr RAM Replacement
    1. HP Pavilion dv6-2158nr RAM Replacement, Battery: step 1, image 1 of 3 HP Pavilion dv6-2158nr RAM Replacement, Battery: step 1, image 2 of 3 HP Pavilion dv6-2158nr RAM Replacement, Battery: step 1, image 3 of 3
      • Locate the battery on the bottom side of the laptop.
      • Slide the release switch and the battery will pop out.
      • Remove the battery
      Ask FixBot
    1. HP Pavilion dv6-2158nr RAM Replacement, RAM: step 2, image 1 of 1
      • Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
      Ask FixBot
    2. HP Pavilion dv6-2158nr RAM Replacement: step 3, image 1 of 3 HP Pavilion dv6-2158nr RAM Replacement: step 3, image 2 of 3 HP Pavilion dv6-2158nr RAM Replacement: step 3, image 3 of 3
      • Remove cover and expose the memory module by lifting the cover up like its on a hinge.
      Ask FixBot
    3. HP Pavilion dv6-2158nr RAM Replacement: step 4, image 1 of 3 HP Pavilion dv6-2158nr RAM Replacement: step 4, image 2 of 3 HP Pavilion dv6-2158nr RAM Replacement: step 4, image 3 of 3
      • Locate the release tabs on both sides of the RAM.
      • Use non-conductive pointing tool or fingers to prevent static build up and damaging components.
      • Pull the metal tabs away from the memory to release it.
      • Pull RAM away from clips to remove from device
      • Repeat for second RAM if necessary
      Ask FixBot
Chad
1,123 Reputation
6 Guides authored
Cal Poly, Team 10-34, Maness Winter 2014 Member of Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 106
All Time: 2,133
