HP Pavilion dv6-1245dx Fan Replacement
    1. HP Pavilion dv6-1245dx Fan Replacement, TouchPad Button: step 1, image 1 of 1
      • Shut down the computer and unplug it from the outlet.
      • Disconnect the power supply cord from the side of the laptop.
      Ask FixBot
    2. HP Pavilion dv6-1245dx Fan Replacement: step 2, image 1 of 1
      • Remove the battery by sliding and holding the battery release latch to the left.
      • While holding the release, lift the battery away from the battery bay and set aside.
      Ask FixBot
    3. HP Pavilion dv6-1245dx Fan Replacement: step 3, image 1 of 1
      • Remove four screws from the battery bay, using the Phillips #00 screwdriver.
      • The screws are 4 mm long and the heads are 4 mm wide.
      • All screw removal/loosening in this guide will require a Phillips #00 screwdriver.
      Ask FixBot
    4. HP Pavilion dv6-1245dx Fan Replacement: step 4, image 1 of 1
      • Starting with the four corners of the laptop, remove all remaining screws from the computer. There will be ten total screws to remove.
      • All ten screws are 7 mm long and the heads are 4 mm wide.
      Ask FixBot
    5. HP Pavilion dv6-1245dx Fan Replacement: step 5, image 1 of 1
      • Loosen the screws from the hard drive bay cover.
      • The screws will not come out all the way.
      • Remove the hard drive bay cover and set aside.
      Ask FixBot
    6. HP Pavilion dv6-1245dx Fan Replacement: step 6, image 1 of 1
      • Remove the hard drive by using the Mylar tab and lifting gently, as it is still connected to the system board by the hard drive cable.
      • Be sure that the computer is turned off and unplugged before removing the hard drive.
      • Discharge yourself of static electricity before handling the hard drive.
      Ask FixBot
    7. HP Pavilion dv6-1245dx Fan Replacement: step 7, image 1 of 1
      • Disconnect the hard drive from the hard drive cable by pulling them apart at the connector. The cable can be difficult to loosen, so while being gentle, you will have to pull hard to disconnect the hard drive.
      • After removing the hard drive, do not touch the connector.
      Ask FixBot
    8. HP Pavilion dv6-1245dx Fan Replacement: step 8, image 1 of 1
      • Loosen the screws from the memory module compartment cover.
      • Remove the memory module compartment cover and set aside.
      Ask FixBot
    9. HP Pavilion dv6-1245dx Fan Replacement: step 9, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 9, image 2 of 2
      • Remove the two memory modules by spreading apart the two silver retaining tabs, using your thumb and index finger. Pull and lift the green memory module upward at a 45-degree angle, then pull the memory module out of the computer.
      • Repeat for the second memory module located directly underneath the first.
      Ask FixBot
    10. HP Pavilion dv6-1245dx Fan Replacement: step 10, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 10, image 2 of 2
      • Disconnect both the black and white (or grey) WLAN antenna cables attached to the WLAN module by lifting gently at the gold base.
      • The cables have stickers labeled "1" and "2". These cables attach to the "J1" and "J2" on the WLAN module.
      Ask FixBot
    11. HP Pavilion dv6-1245dx Fan Replacement: step 11, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 11, image 2 of 2
      • Remove the single silver screw from the WLAN module, and pull the module away from the slot at a 45-degree angle.
      • The screw is 4 mm long and the head is 4 mm wide.
      Ask FixBot
    12. HP Pavilion dv6-1245dx Fan Replacement: step 12, image 1 of 1
      • Remove the hard drive connector from the system board by lifting the Mylar tab.
      Ask FixBot
    13. HP Pavilion dv6-1245dx Fan Replacement: step 13, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 13, image 2 of 2
      • Remove the screw that secures the optical drive to the computer.
      • The screw must be fully removed for the optical drive to be properly removed.
      • The screw is 7 mm long and the head is 4 mm wide.
      Ask FixBot
    14. HP Pavilion dv6-1245dx Fan Replacement: step 14, image 1 of 1
      • Insert a paperclip into the disk tray release access hole of the optical drive. The disk tray will eject automatically when the paperclip reaches the release.
      • Before removing the optical drive, be sure that a disc is not in the drive. Like all drives, optical drives are fragile, so handle with care.
      • Several attempts may be necessary to reach the disk tray release access hole, as it is located pretty far back within the optical drive.
      Ask FixBot
    15. HP Pavilion dv6-1245dx Fan Replacement: step 15, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 15, image 2 of 2
      • Remove the 4 screws marked with keyboard symbols. One is located to the left of the memory module, two are in the hard drive bay, and one is in the battery bay.
      • The screws are 7 mm long and the heads are 4 mm wide.
      Ask FixBot
    16. HP Pavilion dv6-1245dx Fan Replacement: step 16, image 1 of 1
      • Flip over the computer so that the keyboard is facing you.
      Ask FixBot
    17. HP Pavilion dv6-1245dx Fan Replacement: step 17, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 17, image 2 of 2
      • Using the plastic opening tool, loosen the switch cover by inserting the tool under the cover and gently pulling up until the switch cover releases. Begin at the top right-hand corner of the keyboard.
      • The switch cover will remain connected to the system board.
      Ask FixBot
    18. HP Pavilion dv6-1245dx Fan Replacement: step 18, image 1 of 1
      • While holding the switch cover up, remove the 3 silver screws underneath that connect the keyboard to the computer.
      Ask FixBot
    19. HP Pavilion dv6-1245dx Fan Replacement: step 19, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 19, image 2 of 2
      • Set the switch cover down, resting on the computer.
      • Lift the keyboard from the base. It will still be attached to the system board.
      Ask FixBot
    20. HP Pavilion dv6-1245dx Fan Replacement: step 20, image 1 of 3 HP Pavilion dv6-1245dx Fan Replacement: step 20, image 2 of 3 HP Pavilion dv6-1245dx Fan Replacement: step 20, image 3 of 3
      • Tilt the bottom edge of keyboard up toward the display. Pull up the black tab to allow removal of the keyboard cable connector. Then pull the cable gently by holding the blue area to remove the cable entirely.
      • Place the keyboard and connector aside.
      Ask FixBot
    21. HP Pavilion dv6-1245dx Fan Replacement: step 21, image 1 of 1
      • Disconnect the LED board cable from the connector on the system board by pulling the blue Mylar tab in the direction of the display (away from you).
      Ask FixBot
    22. HP Pavilion dv6-1245dx Fan Replacement: step 22, image 1 of 1
      • Disconnect the power button board cable from the connector on the system board by pulling the blue Mylar tab toward the display (away from you).
      • Place the switch cover aside.
      Ask FixBot
    23. HP Pavilion dv6-1245dx Fan Replacement: step 23, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 23, image 2 of 2
      • In the upper left-hand corner of the laptop, disconnect the display panel cable by lifting the Mylar tab upwards toward the screen to release from the connector.
      • The display panel cable can remain connected to the system board.
      Ask FixBot
    24. HP Pavilion dv6-1245dx Fan Replacement: step 24, image 1 of 3 HP Pavilion dv6-1245dx Fan Replacement: step 24, image 2 of 3 HP Pavilion dv6-1245dx Fan Replacement: step 24, image 3 of 3
      • Lift up the yellow tape attached to reveal the webcam/microphone cable. Release the cables from under the grey clip built in to the top cover by gently pushing them away with the spudger.
      • Use the flat end of the spudger to detach the silver webcam/microphone cable from the system board by pulling the white connector away from the system board.
      Ask FixBot
    25. HP Pavilion dv6-1245dx Fan Replacement: step 25, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 25, image 2 of 2
      • Disconnect the power connector cable by using the flat end of the spudger tool. Gently pry the cable until it completely disconnects, or you are able to grab the plastic piece, NOT the wires, to remove the cable.
      • This may be difficult. The pryer tool should touch only the plastic pieces.
      Ask FixBot
    26. HP Pavilion dv6-1245dx Fan Replacement: step 26, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 26, image 2 of 2
      • Disconnect the audio cable from the system board using the spudger tool.
      Ask FixBot
    27. HP Pavilion dv6-1245dx Fan Replacement: step 27, image 1 of 1
      • Disconnect the TouchPad cable from the system board by pulling the blue Mylar tab toward you.
      Ask FixBot
    28. HP Pavilion dv6-1245dx Fan Replacement: step 28, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 28, image 2 of 2
      • Support the display assembly while removing these next screws to avoid damage to the display screen.
      • Remove the 4 screws that fasten the display assembly to the computer. Carefully lift the display assembly off the computer and set aside.
      Ask FixBot
    29. HP Pavilion dv6-1245dx Fan Replacement: step 29, image 1 of 1
      • On the side of the computer farthest away from you, remove the 3 black screws from the top cover.
      Ask FixBot
    30. HP Pavilion dv6-1245dx Fan Replacement: step 30, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 30, image 2 of 2
      • Turn the computer over so the bottom is facing up and the battery bay is facing away from you.
      • Remove the screw directly above the Intel card next to the TV symbol.
      Ask FixBot
    31. HP Pavilion dv6-1245dx Fan Replacement: step 31, image 1 of 1
      Ask FixBot
    32. HP Pavilion dv6-1245dx Fan Replacement: step 32, image 1 of 3 HP Pavilion dv6-1245dx Fan Replacement: step 32, image 2 of 3 HP Pavilion dv6-1245dx Fan Replacement: step 32, image 3 of 3
      • Starting in the optical drive area, slide the plastic opening tool under the top cover, prying up each side to loosen it from the computer.
      • Remove the screw attaching the cover to the system board.
      • The screw is 4 mm long and the head is 5 mm wide.
      • If you are having a hard time removing the cover, turn the computer over to ensure you removed all screws as mentioned in previous steps.
      Ask FixBot
    33. HP Pavilion dv6-1245dx Fan Replacement: step 33, image 1 of 1
      • Now that the top cover is removed, check for debris or food particles that may have become trapped underneath the top cover's TrackPad button area.
      • Optional: Use compressed air to clean out dust and debris.
      • If the TrackPad button is broken, you will need to replace the entire top cover piece purchase and install HP spare part number 518789-001.
      Ask FixBot
    1. HP Pavilion dv6-1245dx Fan Replacement, Fan: step 34, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement, Fan: step 34, image 2 of 2
      • Orient the computer so that the display assembly area is facing away from you.
      • Disconnect the modem cable from the green modem module by using your thumb and forefinger to free the black connector from the modem module.
      • You may need to move the modem cable back and forth several times to release it.
      Ask FixBot
    2. HP Pavilion dv6-1245dx Fan Replacement: step 35, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 35, image 2 of 2
      • On the side facing closest to you, pull right on the blue tab of the audio/infrared board cable to release from the connector on the system board.
      Ask FixBot
    3. HP Pavilion dv6-1245dx Fan Replacement: step 36, image 1 of 1
      • Remove the black screw on the bottom right corner of system board.
      Ask FixBot
    4. HP Pavilion dv6-1245dx Fan Replacement: step 37, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 37, image 2 of 2
      • Holding the right side of the system board at the optical drive area, lift the right-side edge up at an angle. Continue lifting the board up and slide it out at at angle to remove.
      • Set the outer cover aside.
      Ask FixBot
    5. HP Pavilion dv6-1245dx Fan Replacement: step 38, image 1 of 1
      • Turn the system board over, and unscrew the three silver screws attached to the fan.
      • The screws will not come all the way out.
      Ask FixBot
    6. HP Pavilion dv6-1245dx Fan Replacement: step 39, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 39, image 2 of 2
      • Disconnect the connector from the system board by pulling the white tab with your thumb and forefinger.
      • Set the system board aside.
      Ask FixBot
    7. HP Pavilion dv6-1245dx Fan Replacement: step 40, image 1 of 2 HP Pavilion dv6-1245dx Fan Replacement: step 40, image 2 of 2
      • Carefully clean the fan using cotton swabs dipped in rubbing alcohol to lightly sweep away dust and debris.
      • If you need to replace a broken fan, purchase and install HP spare part number 512830-001.
      Ask FixBot
11 other people completed this guide.
Jennifer
594 Reputation
3 Guides authored
2 Guide Comments
I want to open the computer fan so that I can remove the dust properly. What type of screwdriver will I need for that?
Ga.M - Reply Share
Excelente, que buen trabajo esta guia
Alejandro Mojica Rodriguez - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 57
All Time: 10,353
