HP Pavilion dv5000 Wifi Card
    1. HP Pavilion dv5000 Wifi Card, Battery: step 1, image 1 of 1
      • Turn off the computer, and unplug it from all external power sources.
      • Lay the computer face-down on a flat surface. Orient the computer to match the image.
      • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
      Ask FixBot
    1. HP Pavilion dv5000 Wifi Card, RAM Cover: step 2, image 1 of 3 HP Pavilion dv5000 Wifi Card, RAM Cover: step 2, image 2 of 3 HP Pavilion dv5000 Wifi Card, RAM Cover: step 2, image 3 of 3
      • Remove the two 5mm Phillips screws on the right side of the RAM cover.
      • Lift the right side of the RAM cover, and remove it.
      Ask FixBot
    1. HP Pavilion dv5000 Wifi Card, Wifi Card: step 3, image 1 of 2 HP Pavilion dv5000 Wifi Card, Wifi Card: step 3, image 2 of 2
      • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
      • The white wire connects to the AUX terminal.
      • The black wire connects to the MAIN terminal.
      Ask FixBot
    2. HP Pavilion dv5000 Wifi Card: step 4, image 1 of 2 HP Pavilion dv5000 Wifi Card: step 4, image 2 of 2
      • Remove the two 6.0mm Phillips screws from the wifi card.
      • Remove the wifi card.
      Ask FixBot
Sam Kaplan
256 Reputation
2 Guides authored
Cal Poly, Team 21-34, Regan Fall 2010 Member of Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 119
All Time: 7,845
