Up to 20% off select tools
HP Pavilion dv5000 Screen Replacement
Views: 15K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
87
All Time:
14,675
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 17
17 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. HP Pavilion dv5000 Screen Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer, and unplug it from all external power sources.
      • Lay the computer face-down on a flat surface. Orient the computer to match the image.
      • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
      Ask FixBot
    1. HP Pavilion dv5000 Screen Replacement, RAM Cover: step 2, image 1 of 3 HP Pavilion dv5000 Screen Replacement, RAM Cover: step 2, image 2 of 3 HP Pavilion dv5000 Screen Replacement, RAM Cover: step 2, image 3 of 3
      • Remove the two 5mm Phillips screws on the right side of the RAM cover.
      • Lift the right side of the RAM cover, and remove it.
      Ask FixBot
    1. HP Pavilion dv5000 Screen Replacement, Wifi Card: step 3, image 1 of 2 HP Pavilion dv5000 Screen Replacement, Wifi Card: step 3, image 2 of 2
      • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
      • The white wire connects to the AUX terminal.
      • The black wire connects to the MAIN terminal.
      Ask FixBot
    2. HP Pavilion dv5000 Screen Replacement: step 4, image 1 of 2 HP Pavilion dv5000 Screen Replacement: step 4, image 2 of 2
      • Remove the two 6.0mm Phillips screws from the wifi card.
      • Remove the wifi card.
      Ask FixBot
    1. HP Pavilion dv5000 Screen Replacement, Keyboard: step 5, image 1 of 1
      • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
      • Remove the three 6.0mm screws.
      • Remove the two 5.0mm screws.
      • Remove the 6.0mm screw in the middle of the battery compartment.
      Ask FixBot
    2. HP Pavilion dv5000 Screen Replacement: step 6, image 1 of 1
      • Turn the computer over and open the screen. This provides access to the screen hinges.
      • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
      Ask FixBot
    3. HP Pavilion dv5000 Screen Replacement: step 7, image 1 of 1
      • Be careful not to bend the keyboard switch cover too far when removing it.
      Ask FixBot
    4. HP Pavilion dv5000 Screen Replacement: step 8, image 1 of 1
      • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
      Ask FixBot
    5. HP Pavilion dv5000 Screen Replacement: step 9, image 1 of 2 HP Pavilion dv5000 Screen Replacement: step 9, image 2 of 2
      • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
      • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
      Ask FixBot
    6. HP Pavilion dv5000 Screen Replacement: step 10, image 1 of 1
      • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
      • Lay the keyboard face down.
      • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
      Ask FixBot
    7. HP Pavilion dv5000 Screen Replacement: step 11, image 1 of 1
      • Lift the keyboard off the keyboard frame.
      Ask FixBot
    1. HP Pavilion dv5000 Screen Replacement, Screen: step 12, image 1 of 2 HP Pavilion dv5000 Screen Replacement, Screen: step 12, image 2 of 2
      • Use the plastic prying tool to disconnect the screen cable from the system board.
      Ask FixBot
    2. HP Pavilion dv5000 Screen Replacement: step 13, image 1 of 2 HP Pavilion dv5000 Screen Replacement: step 13, image 2 of 2
      • Remove the four 7.0mm screws securing the screen to the computer.
      Ask FixBot
    3. HP Pavilion dv5000 Screen Replacement: step 14, image 1 of 2 HP Pavilion dv5000 Screen Replacement: step 14, image 2 of 2
      • Separate the screen from the computer frame by lifting the screen straight up.
      • Disconnect the PCI wires by pulling them free of the computer.
      Ask FixBot
3 other people completed this guide.
Author
with
Thanh Nguyen
414 Reputation
2 Guides authored
Cal Poly, Team 21-34, Regan Fall 2010 Member of Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Members
132 Guides authored
1 Guide Comment
To reinstall the PCI WIRES I'm finding no other way to reattach them except by removing the outer cover AND RE-ATTACHING. . I will finish-up the repair and send you my results
Christopher Rouse - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 87
All Time: 14,675
