Up to 20% off select tools
HP Pavilion dv5000 RAM Replacement
Views: 16K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
96
All Time:
15,955
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
If your memory is full or having memory problems, then you can easily replace the RAM.
Prerequisties:
Remove the battery and the Hard drive before starting this guide.
    1. HP Pavilion dv5000 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer, and unplug it from all external power sources.
      • Lay the computer face-down on a flat surface. Orient the computer to match the image.
      • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
      Ask FixBot
    1. HP Pavilion dv5000 RAM Replacement, RAM Cover: step 2, image 1 of 3 HP Pavilion dv5000 RAM Replacement, RAM Cover: step 2, image 2 of 3 HP Pavilion dv5000 RAM Replacement, RAM Cover: step 2, image 3 of 3
      • Remove the two 5mm Phillips screws on the right side of the RAM cover.
      • Lift the right side of the RAM cover, and remove it.
      Ask FixBot
    1. HP Pavilion dv5000 RAM Replacement, RAM: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Release the RAM by pressing the metal heads of the RAM clips to the sides. Use tweezers and the spudger to spread the clips until they are completely off the RAM.
      • There are two RAM cards in this device.
      Ask FixBot
    2. HP Pavilion dv5000 RAM Replacement: step 4, image 1 of 3 HP Pavilion dv5000 RAM Replacement: step 4, image 2 of 3 HP Pavilion dv5000 RAM Replacement: step 4, image 3 of 3
      • Remove the RAM.
      Ask FixBot
    3. HP Pavilion dv5000 RAM Replacement: step 5, image 1 of 1
      • As in step 3, press the clips on both sides to release the second RAM clip.
      Ask FixBot
    4. HP Pavilion dv5000 RAM Replacement: step 6, image 1 of 3 HP Pavilion dv5000 RAM Replacement: step 6, image 2 of 3 HP Pavilion dv5000 RAM Replacement: step 6, image 3 of 3
      • Remove the RAM.
      Ask FixBot
2 other people completed this guide.
Author
with
Thanh Nguyen
414 Reputation
2 Guides authored
Cal Poly, Team 21-34, Regan Fall 2010 Member of Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 96
All Time: 15,955
