Up to 20% off select tools
HP Pavilion dv5000 Keyboard Replacement
Views: 12K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
91
All Time:
12,226
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the keyboard, in case you need to replace it.
    1. HP Pavilion dv5000 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer, and unplug it from all external power sources.
      • Lay the computer face-down on a flat surface. Orient the computer to match the image.
      • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
      Ask FixBot
    1. HP Pavilion dv5000 Keyboard Replacement, Keyboard: step 2, image 1 of 1
      • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
      • Remove the three 6.0mm screws.
      • Remove the two 5.0mm screws.
      • Remove the 6.0mm screw in the middle of the battery compartment.
      Ask FixBot
    2. HP Pavilion dv5000 Keyboard Replacement: step 3, image 1 of 1
      • Turn the computer over and open the screen. This provides access to the screen hinges.
      • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
      Ask FixBot
    3. HP Pavilion dv5000 Keyboard Replacement: step 4, image 1 of 1
      • Be careful not to bend the keyboard switch cover too far when removing it.
      Ask FixBot
    4. HP Pavilion dv5000 Keyboard Replacement: step 5, image 1 of 1
      • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
      Ask FixBot
    5. HP Pavilion dv5000 Keyboard Replacement: step 6, image 1 of 2 HP Pavilion dv5000 Keyboard Replacement: step 6, image 2 of 2
      • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
      • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
      Ask FixBot
    6. HP Pavilion dv5000 Keyboard Replacement: step 7, image 1 of 1
      • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
      • Lay the keyboard face down.
      • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
      Ask FixBot
    7. HP Pavilion dv5000 Keyboard Replacement: step 8, image 1 of 1
      • Lift the keyboard off the keyboard frame.
      Ask FixBot
6 other people completed this guide.
Author
with
Alex Kwok
274 Reputation
3 Guides authored
Cal Poly, Team 21-34, Regan Fall 2010 Member of Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Members
132 Guides authored
2 Guide Comments
Hey is keyboard replacement same or very similiar procedure with hp dv8000?
Arkadiusz Gąsior - Reply Share
Brilliant. This is the best tutorial out there. Many thanks indeed!!!!
stevefranklin75 - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 91
All Time: 12,226
