HP Pavilion dv4000 CD/DVD drive Replacement
    1. HP Pavilion dv4000 CD/DVD drive Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside down with the battery compartment facing you.
      Ask FixBot
    2. HP Pavilion dv4000 CD/DVD drive Replacement: step 2, image 1 of 1
      • Slide the battery release latch to the right and hold in place.
      Ask FixBot
    3. HP Pavilion dv4000 CD/DVD drive Replacement: step 3, image 1 of 1
      • Lift the front edge of the battery up and remove it from the compartment.
      Ask FixBot
    1. HP Pavilion dv4000 CD/DVD drive Replacement, Hard Drive: step 4, image 1 of 1
      • Orient the laptop with the hard drive panel towards you.
      Ask FixBot
    2. HP Pavilion dv4000 CD/DVD drive Replacement: step 5, image 1 of 1
      • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
      Ask FixBot
    3. HP Pavilion dv4000 CD/DVD drive Replacement: step 6, image 1 of 2 HP Pavilion dv4000 CD/DVD drive Replacement: step 6, image 2 of 2
      • Lift the cover up by the tab near the screws.
      • The cover can be removed from the laptop.
      Ask FixBot
    4. HP Pavilion dv4000 CD/DVD drive Replacement: step 7, image 1 of 1
      • Grab the hard drive from the sides and slide it away from the connectors.
      • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
      • Lift and remove the hard drive from the laptop.
      • We did not have a hard drive in our laptop to demonstrate how to remove it.
      Ask FixBot
    1. HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: step 8, image 1 of 2 HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: step 8, image 2 of 2
      • Locate the one 2x5 mm screw in the hard drive bay.
      • Unscrew the screw with a #00 Phillips screwdriver.
      Ask FixBot
    2. HP Pavilion dv4000 CD/DVD drive Replacement: step 9, image 1 of 3 HP Pavilion dv4000 CD/DVD drive Replacement: step 9, image 2 of 3 HP Pavilion dv4000 CD/DVD drive Replacement: step 9, image 3 of 3
      • Locate the hole next to the DVD drive release button.
      • Insert a paperclip into the hole to release the DVD drive.
      Ask FixBot
    3. HP Pavilion dv4000 CD/DVD drive Replacement: step 10, image 1 of 2 HP Pavilion dv4000 CD/DVD drive Replacement: step 10, image 2 of 2
      • Carefully grasp the DVD drive and slide it out.
      Ask FixBot
4 other people completed this guide.
Nick LaMarche
373 Reputation
2 Guides authored
UMass Dartmouth, Team 4-2, Catania Fall 2016 Member of UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 1,538
