HP Pavilion dv4-4141us RAM Replacement
    1. HP Pavilion dv4-4141us RAM Replacement, RAM: step 1, image 1 of 1
      • Lift up the back panel using a spudger and remove it from the device.
      Ask FixBot
    2. HP Pavilion dv4-4141us RAM Replacement: step 2, image 1 of 1
      • Push the two metal clips away from each other to release the RAM.
      Ask FixBot
    3. HP Pavilion dv4-4141us RAM Replacement: step 3, image 1 of 2 HP Pavilion dv4-4141us RAM Replacement: step 3, image 2 of 2
      • Each RAM stick will pop up at a 45 degree angle.
      • Pull the RAM up and away and remove it from the device.
      • Do not use a metal spudger for this step. Incorrect use of the metal spudger can damage the internal components in your device.
      Ask FixBot
Vincent Gardner
390 Reputation
3 Guides authored
UMass Dartmouth, Team 2-3, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-3, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G3
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 54
All Time: 389
