Up to 20% off select tools
HP Pavilion dv2913cl RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
77
All Time:
619
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Is your HP Pavilion dv2913cl running slower than usual or freezing frequently? These common issues may be due to faulty or insufficient RAM. By replacing or upgrading the RAM, you can potentially restore your laptop's performance to an optimal or improved state.
Random Access memory (RAM) is an important part of the computer and contributes to how smoothly it can run. If the RAM is faulty, the computer will have issues such as becoming slow or crashing when running complex or intensive programs.
This step-by-step guide is designed to help you access and replace the RAM modules in your HP Pavilion dv2913cl. The process is simple and beginner-friendly, requiring no advanced technical skills.
Before You Begin:
  • Safety First: Power off your laptop and unplug it from any power source to avoid electrical hazards.
  • Preparation: Gather the necessary tools and ensure you’re working in a clean, static-free environment to prevent accidental damage to components.
  • Check RAM is connected: Before beginning, check the BIOS and any other relevant software to ensure the problem is a broken RAM and not an issue with the RAM connection.
Follow this guide carefully, and you'll have your HP Pavilion dv2913cl running smoothly in no time!
    1. HP Pavilion dv2913cl RAM  Replacement, Ram: step 1, image 1 of 2 HP Pavilion dv2913cl RAM  Replacement, Ram: step 1, image 2 of 2
      • Unscrew the two screws on the center panel of the device .
      • Then gently remove the center panel.
      Ask FixBot
    2. HP Pavilion dv2913cl RAM  Replacement: step 2, image 1 of 3 HP Pavilion dv2913cl RAM  Replacement: step 2, image 2 of 3 HP Pavilion dv2913cl RAM  Replacement: step 2, image 3 of 3
      • Gently push the silver clamps on both sides of the RAM stick on top far enough to release the RAM card.
      • Pushing the clamps too far could damage them.
      • Remove the other RAM stick.
      Ask FixBot
    3. HP Pavilion dv2913cl RAM  Replacement: step 3, image 1 of 1
      • This is the device with both RAM sticks removed.
      Ask FixBot
Author
with
Jeremy Jackson
209 Reputation
2 Guides authored
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 77
All Time: 619
