HP Pavilion dv2000 Wireless Card Replacement
    1. HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: step 1, image 1 of 2 HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: step 1, image 2 of 2
      • Make sure your computer is powered down and unplugged from the charger before removing any components.
      • Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
      • Lift up and remove the wireless card casing.
      • The 3.8mm screw will remain in the wireless card casing after you unscrew it.
      Ask FixBot
    2. HP Pavilion dv2000 Wireless Card Replacement: step 2, image 1 of 2 HP Pavilion dv2000 Wireless Card Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the three antennas from their sockets.
      • Remove the antennas by the contacts connected to the socket, the crimps connecting the wires and the sockets are delicate and are easily damaged.
      Ask FixBot
    3. HP Pavilion dv2000 Wireless Card Replacement: step 3, image 1 of 3 HP Pavilion dv2000 Wireless Card Replacement: step 3, image 2 of 3 HP Pavilion dv2000 Wireless Card Replacement: step 3, image 3 of 3
      Phillips #00 Screwdriver
      $5.49
      Buy
      • Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
      • Gently pull out your wireless card from its top side to remove it from its holding.
      Ask FixBot
3 other people completed this guide.
Erik Muniz
847 Reputation
3 Guides authored
CSU Fullerton, Team 2-3, Bruce Fall 2014 Member of CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 111
All Time: 2,969
