HP Pavilion dv2000 Hard Drive Replacement
    1. HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      Tool used on this step:
      Phillips #00 Screwdriver
      $5.49
      Buy
      • Flip your computer over, so that the underside of your computer is facing upward.
      • Make sure your computer is powered down and unplugged from the charger before removing any components.
      • Locate the hard drive casing on the bottom-right corner of your flipped computer.
      • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
      • Screws on hard drive casing will remain in casing after being unscrewed.
      Ask FixBot
    2. HP Pavilion dv2000 Hard Drive Replacement: step 2, image 1 of 3 HP Pavilion dv2000 Hard Drive Replacement: step 2, image 2 of 3 HP Pavilion dv2000 Hard Drive Replacement: step 2, image 3 of 3
      Phillips #000 Screwdriver
      $5.49
      Buy
      • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
      • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
      Ask FixBot
7 other people completed this guide.
Erik Muniz
847 Reputation
3 Guides authored
CSU Fullerton, Team 2-3, Bruce Fall 2014 Member of CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Members
36 Guides authored
1 Guide Comment
You didnt mention this HDD has a different SATA connector , I cant find it in the market, instead of plug in , this one is for pressing down only
tml215 - Reply Share
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 127
All Time: 5,125
