Up to 20% off select tools
HP Pavilion dv1000 RAM Replacement
Views: 9.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
92
All Time:
9,834
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. HP Pavilion dv1000 RAM Replacement, Battery: step 1, image 1 of 1
      • Shut down the computer.
      • Disconnect all external devices and cables from the computer.
      Ask FixBot
    2. HP Pavilion dv1000 RAM Replacement: step 2, image 1 of 1
      • Flip the laptop over.
      Ask FixBot
    3. HP Pavilion dv1000 RAM Replacement: step 3, image 1 of 2 HP Pavilion dv1000 RAM Replacement: step 3, image 2 of 2
      • Locate the gray sliding tab next to the black bar where the battery is located.
      • Slide the gray sliding tab to the left until you hear a distinct click.
      • The inside edge of the battery should pop up.
      Ask FixBot
    4. HP Pavilion dv1000 RAM Replacement: step 4, image 1 of 3 HP Pavilion dv1000 RAM Replacement: step 4, image 2 of 3 HP Pavilion dv1000 RAM Replacement: step 4, image 3 of 3
      • Grasp the inside edge of the battery.
      • Lift the inside edge of the battery up to detach the battery from the laptop.
      Ask FixBot
    1. HP Pavilion dv1000 RAM Replacement, RAM: step 5, image 1 of 1
      • Locate RAM access door on the bottom side of the laptop.
      Ask FixBot
    2. HP Pavilion dv1000 RAM Replacement: step 6, image 1 of 3 HP Pavilion dv1000 RAM Replacement: step 6, image 2 of 3 HP Pavilion dv1000 RAM Replacement: step 6, image 3 of 3
      • Locate the two screws holding down the RAM access cover
      • Unscrew the two screws with a size 00 Philips screwdriver.
      • Note: The screws do not detach from the cover.
      Ask FixBot
    3. HP Pavilion dv1000 RAM Replacement: step 7, image 1 of 2 HP Pavilion dv1000 RAM Replacement: step 7, image 2 of 2
      • Lift up on the screw side of the RAM access cover to remove it.
      Ask FixBot
    4. HP Pavilion dv1000 RAM Replacement: step 8, image 1 of 2 HP Pavilion dv1000 RAM Replacement: step 8, image 2 of 2
      • Gently pull apart the metal tabs located on both sides of the stick of RAM.
      • The RAM stick should tilt upwards.
      Ask FixBot
    5. HP Pavilion dv1000 RAM Replacement: step 9, image 1 of 1
      • Gently lift the the RAM up and out of its seat.
      Ask FixBot
    6. HP Pavilion dv1000 RAM Replacement: step 10, image 1 of 1
      • Repeat the previous two steps for the remaining stick of RAM.
      Ask FixBot
5 other people completed this guide.
Author
with
Henry OBrien
104 Reputation
1 Guide authored
Cal Poly, Team 10-37, Forte Spring 2011 Member of Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Members
96 Guides authored
2 Guide Comments
THANKS - YOU'RE AWESOME!!!! Removing the hard drive was the fix it! the HP site never tells you this - imagine.......
marena - Reply Share
I had never dealt with laptop ram before and i used this guide sussusfully to remove the ram from my old HP Pavilliondv6-3055dx laptop. Thanks!
Andrew Lonero - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 92
All Time: 9,834
