HP Pavilion dv1000 Media Keys Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
98
All Time:
1,256
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HP Pavilion dv1000 Media Keys Replacement, Battery: step 1, image 1 of 1
      • Shut down the computer.
      • Disconnect all external devices and cables from the computer.
      Ask FixBot
    2. HP Pavilion dv1000 Media Keys Replacement: step 2, image 1 of 1
      • Flip the laptop over.
      Ask FixBot
    3. HP Pavilion dv1000 Media Keys Replacement: step 3, image 1 of 2 HP Pavilion dv1000 Media Keys Replacement: step 3, image 2 of 2
      • Locate the gray sliding tab next to the black bar where the battery is located.
      • Slide the gray sliding tab to the left until you hear a distinct click.
      • The inside edge of the battery should pop up.
      Ask FixBot
    4. HP Pavilion dv1000 Media Keys Replacement: step 4, image 1 of 3 HP Pavilion dv1000 Media Keys Replacement: step 4, image 2 of 3 HP Pavilion dv1000 Media Keys Replacement: step 4, image 3 of 3
      • Grasp the inside edge of the battery.
      • Lift the inside edge of the battery up to detach the battery from the laptop.
      Ask FixBot
    1. HP Pavilion dv1000 Media Keys Replacement, Keyboard: step 5, image 1 of 1
      • Remove the highlighted screws.
      • After removing the screws, flip the laptop over.
      Ask FixBot
    2. HP Pavilion dv1000 Media Keys Replacement: step 6, image 1 of 2 HP Pavilion dv1000 Media Keys Replacement: step 6, image 2 of 2
      • Open the laptop.
      • Use the spudger to lift the keyboard.
      • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
      • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
      Ask FixBot
    1. HP Pavilion dv1000 Media Keys Replacement, Media Keys: step 7, image 1 of 1
      • Turn the laptop upside-down again.
      Ask FixBot
    2. HP Pavilion dv1000 Media Keys Replacement: step 8, image 1 of 2 HP Pavilion dv1000 Media Keys Replacement: step 8, image 2 of 2
      • Turn the laptop right-side up. Open the screen and tilt it all the way back.
      • Locate the media keys.
      • Gently lift up the media key strip using the plastic pry tool.
      • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
      Ask FixBot
Tyler Latour
275 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 98
All Time: 1,256
