HP Pavilion dv1000 Keyboard Replacement
    1. HP Pavilion dv1000 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Shut down the computer.
      • Disconnect all external devices and cables from the computer.
      Ask FixBot
    2. HP Pavilion dv1000 Keyboard Replacement: step 2, image 1 of 1
      • Flip the laptop over.
      Ask FixBot
    3. HP Pavilion dv1000 Keyboard Replacement: step 3, image 1 of 2 HP Pavilion dv1000 Keyboard Replacement: step 3, image 2 of 2
      • Locate the gray sliding tab next to the black bar where the battery is located.
      • Slide the gray sliding tab to the left until you hear a distinct click.
      • The inside edge of the battery should pop up.
      Ask FixBot
    4. HP Pavilion dv1000 Keyboard Replacement: step 4, image 1 of 3 HP Pavilion dv1000 Keyboard Replacement: step 4, image 2 of 3 HP Pavilion dv1000 Keyboard Replacement: step 4, image 3 of 3
      • Grasp the inside edge of the battery.
      • Lift the inside edge of the battery up to detach the battery from the laptop.
      Ask FixBot
    1. HP Pavilion dv1000 Keyboard Replacement, Keyboard: step 5, image 1 of 1
      • Remove the highlighted screws.
      • After removing the screws, flip the laptop over.
      Ask FixBot
    2. HP Pavilion dv1000 Keyboard Replacement: step 6, image 1 of 2 HP Pavilion dv1000 Keyboard Replacement: step 6, image 2 of 2
      • Open the laptop.
      • Use the spudger to lift the keyboard.
      • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
      • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
      Ask FixBot
Tyler Latour
275 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 101
All Time: 2,154
