HP Pavilion dv1000 Bluetooth Card Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
99
All Time:
5,696
Comments: 3
3 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This guide will teach you how to safely take apart your laptop and access the faulty or broken Bluetooth card, in order to repair or replace it.
Tools
    1. HP Pavilion dv1000 Bluetooth Card Replacement, Battery: step 1, image 1 of 1
      • Shut down the computer.
      • Disconnect all external devices and cables from the computer.
      Ask FixBot
    2. HP Pavilion dv1000 Bluetooth Card Replacement: step 2, image 1 of 1
      • Flip the laptop over.
      Ask FixBot
    3. HP Pavilion dv1000 Bluetooth Card Replacement: step 3, image 1 of 2 HP Pavilion dv1000 Bluetooth Card Replacement: step 3, image 2 of 2
      • Locate the gray sliding tab next to the black bar where the battery is located.
      • Slide the gray sliding tab to the left until you hear a distinct click.
      • The inside edge of the battery should pop up.
      Ask FixBot
    4. HP Pavilion dv1000 Bluetooth Card Replacement: step 4, image 1 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 4, image 2 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 4, image 3 of 3
      • Grasp the inside edge of the battery.
      • Lift the inside edge of the battery up to detach the battery from the laptop.
      Ask FixBot
    1. HP Pavilion dv1000 Bluetooth Card Replacement, Hard Drive: step 5, image 1 of 1
      • With the battery removed, locate the hard drive access panel.
      Ask FixBot
    2. HP Pavilion dv1000 Bluetooth Card Replacement: step 6, image 1 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 6, image 2 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 6, image 3 of 3
      • Identify the two screws that attach the hard drive access panel.
      • Remove the identified screws with your #00 Philips screwdriver.
      • Lift the left edge of the access panel up and to the right to detach the hard drive access panel from the laptop.
      Ask FixBot
    3. HP Pavilion dv1000 Bluetooth Card Replacement: step 7, image 1 of 1
      • This particular laptop does not contain a hard drive-- yours will.
      • Identify the plastic tab located on the left side of the hard drive.
      • Grasp the tab, gently lift up, and slide the tab to the left to remove the hard drive from the laptop.
      • If you wish to replace your hard drive with another, the hard drive has a metal bracket screwed onto the sides of the casing. Unscrew the bracket from the old hard drive and screw it onto the new hard drive before inserting into the laptop.
      Ask FixBot
    1. HP Pavilion dv1000 Bluetooth Card Replacement, RAM: step 8, image 1 of 1
      • Locate RAM access door on the bottom side of the laptop.
      Ask FixBot
    2. HP Pavilion dv1000 Bluetooth Card Replacement: step 9, image 1 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 9, image 2 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 9, image 3 of 3
      • Locate the two screws holding down the RAM access cover
      • Unscrew the two screws with a size 00 Philips screwdriver.
      • Note: The screws do not detach from the cover.
      Ask FixBot
    3. HP Pavilion dv1000 Bluetooth Card Replacement: step 10, image 1 of 2 HP Pavilion dv1000 Bluetooth Card Replacement: step 10, image 2 of 2
      • Lift up on the screw side of the RAM access cover to remove it.
      Ask FixBot
    4. HP Pavilion dv1000 Bluetooth Card Replacement: step 11, image 1 of 2 HP Pavilion dv1000 Bluetooth Card Replacement: step 11, image 2 of 2
      • Gently pull apart the metal tabs located on both sides of the stick of RAM.
      • The RAM stick should tilt upwards.
      Ask FixBot
    5. HP Pavilion dv1000 Bluetooth Card Replacement: step 12, image 1 of 1
      • Gently lift the the RAM up and out of its seat.
      Ask FixBot
    6. HP Pavilion dv1000 Bluetooth Card Replacement: step 13, image 1 of 1
      • Repeat the previous two steps for the remaining stick of RAM.
      Ask FixBot
    1. HP Pavilion dv1000 Bluetooth Card Replacement, Bluetooth Card: step 14, image 1 of 3 HP Pavilion dv1000 Bluetooth Card Replacement, Bluetooth Card: step 14, image 2 of 3 HP Pavilion dv1000 Bluetooth Card Replacement, Bluetooth Card: step 14, image 3 of 3
      • Locate the small panel below the panel you just removed.
      • Loosen the one screw in the middle with a #00 Phillips screwdriver. Again, the screw will not fall out of the panel when loosened.
      • Lift the panel up and out of its slot to remove.
      Ask FixBot
    2. HP Pavilion dv1000 Bluetooth Card Replacement: step 15, image 1 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 15, image 2 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 15, image 3 of 3
      • Identify the two connections at the top of the bluetooth card.
      • Using your fingers, gently pull up on the white clip until it releases.
      • Remove the black clip in the same manner as the white clip
      Ask FixBot
    3. HP Pavilion dv1000 Bluetooth Card Replacement: step 16, image 1 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 16, image 2 of 3 HP Pavilion dv1000 Bluetooth Card Replacement: step 16, image 3 of 3
      • Locate the two clips on either side of the Bluetooth card.
      • Using your fingers, press the clips outwards, away from the card until the card pops up.
      • Grab the card gently from the top and pull the card up and out of the slot.
      Ask FixBot
3 other people completed this guide.
Ross Johnson
182 Reputation
2 Guides authored
Cal Poly, Team 10-37, Forte Spring 2011 Member of Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 99
All Time: 5,696
