HP Pavilion dm4-1265dx RAM Replacement
    1. HP Pavilion dm4-1265dx RAM Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop over so the bottom is facing up.
      Ask FixBot
    2. HP Pavilion dm4-1265dx RAM Replacement: step 2, image 1 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 2, image 2 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 2, image 3 of 3
      • Push the sliding lock to release the battery.
      • Remove the battery by lifting it away from the device.
      Ask FixBot
    1. HP Pavilion dm4-1265dx RAM Replacement, Back Panel: step 3, image 1 of 2 HP Pavilion dm4-1265dx RAM Replacement, Back Panel: step 3, image 2 of 2
      • Orient the device so that the empty battery port is closest to you.
      • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
      Ask FixBot
    2. HP Pavilion dm4-1265dx RAM Replacement: step 4, image 1 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 4, image 2 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 4, image 3 of 3
      • Pull back and lift the back panel to remove it from the device.
      Ask FixBot
    1. HP Pavilion dm4-1265dx RAM Replacement, RAM: step 5, image 1 of 3 HP Pavilion dm4-1265dx RAM Replacement, RAM: step 5, image 2 of 3 HP Pavilion dm4-1265dx RAM Replacement, RAM: step 5, image 3 of 3
      • Push the two clips on either side of the top RAM stick away from each other.
      Ask FixBot
    2. HP Pavilion dm4-1265dx RAM Replacement: step 6, image 1 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 6, image 2 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 6, image 3 of 3
      • Pull the top RAM stick upwards.
      • The RAM stick should be at an angle to the device.
      • Gently pull the RAM stick away from the socket.
      Ask FixBot
    3. HP Pavilion dm4-1265dx RAM Replacement: step 7, image 1 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 7, image 2 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 7, image 3 of 3
      • Push the two clips on either side of the lower RAM stick away from each other.
      Ask FixBot
    4. HP Pavilion dm4-1265dx RAM Replacement: step 8, image 1 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 8, image 2 of 3 HP Pavilion dm4-1265dx RAM Replacement: step 8, image 3 of 3
      • Pull the lower RAM stick upwards.
      Ask FixBot
Ethan Redfern
137 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 71
All Time: 640
