HP Pavilion ZD7000 Wi-Fi Card Replacement
    1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Battery: step 1, image 1 of 1
      • Begin by turning the laptop over so that you can see the bottom of the computer.
      Ask FixBot
    2. HP Pavilion ZD7000 Wi-Fi Card Replacement: step 2, image 1 of 1
      • Slide the battery release switch to the right while simultaneously lifting up the battery.
      Ask FixBot
    1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 2 HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 2 of 2
      • Unscrew the 2 screws from the plate that cover the Wi-Fi card.
      • Remove the cover.
      Ask FixBot
    2. HP Pavilion ZD7000 Wi-Fi Card Replacement: step 4, image 1 of 2 HP Pavilion ZD7000 Wi-Fi Card Replacement: step 4, image 2 of 2
      • Disconnect these 2 antenna wires (which eventually connect to the monitor) from the Wi-Fi card.
      • For reassembly, note where the black and white cables connect to the card.
      • Release the Wi-Fi card from the laptop by pressing the metal hinges on either end of it.
      • Gently remove the card from laptop.
      Ask FixBot
3 other people completed this guide.
Shantel
563 Reputation
6 Guides authored
Cal Poly, Team 30-37, Garner Spring 2010 Member of Cal Poly, Team 30-37, Garner Spring 2010
CPSU-GARNER-S10S30G37
4 Members
72 Guides authored
2 Guide Comments
Can you upgrade the wifi card?
danoco - Reply Share
is there a replacement I can buy
Braeden Culp - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 49
All Time: 5,848
