HP Pavilion Wave 600-a014 RAM Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
90
All Time:
3,597
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your computer has errors or just needs a speed boost, consider changing the RAM by following this guide.
Parts
Tools
    1. HP Pavilion Wave 600-a014 RAM Replacement, RAM: step 1, image 1 of 1
      • Disconnect PC from power source and any other devices.
      Ask FixBot
    2. HP Pavilion Wave 600-a014 RAM Replacement: step 2, image 1 of 2 HP Pavilion Wave 600-a014 RAM Replacement: step 2, image 2 of 2
      • Turn over computer and remove the rubber feet.
      • Remove the three 8mm Philips screws with a Philips #0 screwdriver.
      • Use a pry tool and lift up on the lid.
      Ask FixBot
    3. HP Pavilion Wave 600-a014 RAM Replacement: step 3, image 1 of 2 HP Pavilion Wave 600-a014 RAM Replacement: step 3, image 2 of 2
      • Remove the two cables connecting the motherboard to the front I/O panel.
      Ask FixBot
    4. HP Pavilion Wave 600-a014 RAM Replacement: step 4, image 1 of 2 HP Pavilion Wave 600-a014 RAM Replacement: step 4, image 2 of 2
      • From the back I/O panel, pry open the cloth covering.
      Ask FixBot
    5. HP Pavilion Wave 600-a014 RAM Replacement: step 5, image 1 of 1
      • Remove the 2 black philips screws on the outside of the PC, to the left of the fan.
      • There is one on the top and one on the bottom.
      Ask FixBot
    6. HP Pavilion Wave 600-a014 RAM Replacement: step 6, image 1 of 3 HP Pavilion Wave 600-a014 RAM Replacement: step 6, image 2 of 3 HP Pavilion Wave 600-a014 RAM Replacement: step 6, image 3 of 3
      • Put your thumb on the penny-sized hole, and slide the panel upwards.
      • Remove the panel to reveal the stock blue RAM.
      Ask FixBot
    7. HP Pavilion Wave 600-a014 RAM Replacement: step 7, image 1 of 3 HP Pavilion Wave 600-a014 RAM Replacement: step 7, image 2 of 3 HP Pavilion Wave 600-a014 RAM Replacement: step 7, image 3 of 3
      • Push both of the white tabs away from the RAM stick to free the RAM.
      Ask FixBot
    8. HP Pavilion Wave 600-a014 RAM Replacement: step 8, image 1 of 1
      • You can now easily pull the RAM out of the socket, and replace up to two new ones!
      Ask FixBot
2 other people completed this guide.
Arthur Knatt
149 Reputation
1 Guide authored
Cal Poly, Team S8-G4, Banghart Fall 2017 Member of Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Members
60 Guides authored
1 Guide Comment
Hello srs, i follow the link to the Amazon Ram, and it is So-DIMM, but we need UDIMM for this Wave, it is correct? Wich can we use? Thank you so much, and best regards.
Albert Garcia - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 90
All Time: 3,597
