HP Pavilion Wave 600-a014 Hard Drive Replacement
  1. HP Pavilion Wave 600-a014 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Disconnect the PC from power source and any other devices.
    Ask FixBot
  2. HP Pavilion Wave 600-a014 Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion Wave 600-a014 Hard Drive Replacement: step 2, image 2 of 2
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
    Ask FixBot
  3. HP Pavilion Wave 600-a014 Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion Wave 600-a014 Hard Drive Replacement: step 3, image 2 of 2
    • Remove the two cables circled in red for the front IO panel.
    Ask FixBot
  4. HP Pavilion Wave 600-a014 Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion Wave 600-a014 Hard Drive Replacement: step 4, image 2 of 2
    • From back IO panel pry open the casing as indicated.
    Ask FixBot
  5. HP Pavilion Wave 600-a014 Hard Drive Replacement: step 5, image 1 of 3 HP Pavilion Wave 600-a014 Hard Drive Replacement: step 5, image 2 of 3 HP Pavilion Wave 600-a014 Hard Drive Replacement: step 5, image 3 of 3
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
    Ask FixBot
  6. HP Pavilion Wave 600-a014 Hard Drive Replacement: step 6, image 1 of 1
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
    Ask FixBot
5 other people completed this guide.
Cristian Vanegas
321 Reputation
2 Guides authored
Cal Poly, Team S8-G4, Banghart Fall 2017 Member of Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Members
5 Guides authored
2 Guide Comments
Hi there, can you advise whether this was the 128gb SSD or the other 2gb drive?
Joey Franco - Reply Share
This model comes with a 3.5" 1TB HDD standard.
Jay Marble - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 35
All Time: 3,064
