HP Pavilion TouchSmart 14z-n100 Keyboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
57
All Time:
489
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide to replace the keyboard on a HP Pavilion TouchSmart 14z-n100. You will need a number 1 Phillips screwdriver, a plastic spudger and a replacement keyboard.
Tools
    1. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Remove these two, 4 mm long number 1 Phillips screws from the device.
      Ask FixBot
    2. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: step 2, image 1 of 1
      • Gently pull the keyboard up with a small plastic opening tool, beginning toward the front right corner. Just pull the keyboard up enough to fit your fingers under.
      Ask FixBot
    3. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: step 3, image 1 of 1
      • Gently pull the keyboard up with your fingers. Do not pull the keyboard too far from the computer.
      Ask FixBot
    4. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: step 4, image 1 of 3 HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: step 4, image 2 of 3 HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: step 4, image 3 of 3
      • Lift the plastic retaining tab with a small plastic opening tool. The tab will rotate to the side but not remove from the laptop. After this gently pull the wire ribbon to remove it. The old keyboard is now completely removed.
      Ask FixBot
Antonio DiMattia
133 Reputation
1 Guide authored
IUPUI, Team S1-G4, Arle Fall 2018 Member of IUPUI, Team S1-G4, Arle Fall 2018
IUPUI-ARLE-F18S1G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 57
All Time: 489
