HP Pavilion TPN-C125 RAM Replacement
    1. HP Pavilion TPN-C125 RAM Replacement, RAM: step 1, image 1 of 2 HP Pavilion TPN-C125 RAM Replacement, RAM: step 1, image 2 of 2
      • Flip the laptop over so the bottom is facing up and the external battery is at the top.
      Ask FixBot
    2. HP Pavilion TPN-C125 RAM Replacement: step 2, image 1 of 2 HP Pavilion TPN-C125 RAM Replacement: step 2, image 2 of 2
      • Use your thumbs to slide the battery locks towards the center and pop the battery out.
      Ask FixBot
    3. HP Pavilion TPN-C125 RAM Replacement: step 3, image 1 of 2 HP Pavilion TPN-C125 RAM Replacement: step 3, image 2 of 2
      • Slowly peel off the two rubber stoppers found at the top corners of the laptop.
      • This will expose two Philips #00 10 mm screws required to remove the back plate.
      • Be careful not to peel off the rubber stoppers too quickly as it could cause the adhesive on the rubber stopper to strip off.
      Ask FixBot
    4. HP Pavilion TPN-C125 RAM Replacement: step 4, image 1 of 2 HP Pavilion TPN-C125 RAM Replacement: step 4, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the twelve 10 mm screws (from the twelve holes shown) that secure the bottom case.
      • Use an opening tool to carefully separate the back case from the chassis, working around all four sides.
      • You will hear a "click" as you release the clips and remove it.
      Ask FixBot
    5. HP Pavilion TPN-C125 RAM Replacement: step 5, image 1 of 3 HP Pavilion TPN-C125 RAM Replacement: step 5, image 2 of 3 HP Pavilion TPN-C125 RAM Replacement: step 5, image 3 of 3
      • The RAM sticks can be found in the bottom right section of the laptop.
      • Push both side arms holding the RAM stick in place outwards.
      • The RAM sticks will "pop" up at a 45-degree angle when released from the arms.
      • Slide the RAM sticks out of the socket gently.
      Ask FixBot
    6. HP Pavilion TPN-C125 RAM Replacement: step 6, image 1 of 3 HP Pavilion TPN-C125 RAM Replacement: step 6, image 2 of 3 HP Pavilion TPN-C125 RAM Replacement: step 6, image 3 of 3
      • Carefully slide the new replacement RAM sticks into their slots.
      • Make sure to align edge of the RAM sticks with the slots to avoid damaging both.
      • Gently push the RAM sticks downward until the latches click into place to secure them.
      Ask FixBot
2 other people completed this guide.
Cesar Gomez
211 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 80
Past 30 Days: 281
All Time: 5,270
