HP Pavilion Notebook 15-ab293cl Hard Drive Replacement
    1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Flip the laptop over so that the battery is facing upward.
      Ask FixBot
    2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 2, image 1 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 2, image 2 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 2, image 3 of 3
      • Slide both tab buttons inward to open the battery cover. Gently push the battery out to remove.
      Ask FixBot
    3. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 3, image 2 of 2
      • Remove the black plastic hinge covers at the top corners of the laptop.
      • Use the Phillips #1 to remove the two 7.5mm screws.
      • Use the opening tool to pry the black covers off of the laptop.
      Ask FixBot
    4. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 4, image 1 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 4, image 2 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 4, image 3 of 3
      • Remember to remove the tabs shown in the second picture.
      • Remove all 16 - 7.5mm screws with the Phillips #1 screwdriver.
      • Pry and slide the CD/DVD drive out of the laptop case.
      Ask FixBot
    5. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 5, image 1 of 1
      • Unscrew the two 3.5mm silver screws with the Phillips #000 and the Philips # 1.
      Ask FixBot
    6. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 6, image 1 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 6, image 2 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 6, image 3 of 3
      • Turn the computer so that the screen faces you.
      • Use the pry tool to pry off the edge of the keyboard side of laptop.
      Ask FixBot
    7. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 7, image 1 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 7, image 2 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 7, image 3 of 3
      • The hard drive is located in the bottom corner of the laptop.
      • Gently lift up the hard drive and pry off the white tab to release the hard drive.
      Ask FixBot
    8. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 8, image 1 of 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 8, image 2 of 2
      • Once you release the white tab from the green board, remove the hard drive.
      Ask FixBot
Efren Solis
228 Reputation
1 Guide authored
Gateway, Team S1-G2, Luster Fall 2018 Member of Gateway, Team S1-G2, Luster Fall 2018
GCC-LUSTER-F18S1G2
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 81
All Time: 3,905
