HP Pavilion Notebook 15-ab293cl CPU Fan Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
69
All Time:
1,785
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 seconds
Difficulty: Moderate
Introduction
Go to step 1 ↓
The cooling fan is essential in order for your laptop to keep from overheating and for it to function at all. Being such an essential part of the laptop as a whole, it is absolutely necessary for it to be running at optimal conditions. Through thorough examination of this guide you will be fully able to access the cooling fan and replace it with ease.
Parts
Tools
    1. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement, CPU Fan: step 1, image 1 of 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement, CPU Fan: step 1, image 2 of 2
      • Start by flipping the laptop, revealing its back.
      Ask FixBot
    2. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 2, image 1 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 2, image 2 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 2, image 3 of 3
      • Slide the tab marked with a lock/unlock symbol. The slide the other tab in order to release the battery.
      Ask FixBot
    3. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 3, image 1 of 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 3, image 2 of 2
      • Once the battery is removed, unscrew and remove the both of the 7.5 mm screws off the black tabs using a PH1 screw driver. Then pry off the covers using the plastic opening tools.
      Ask FixBot
    4. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 4, image 1 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 4, image 2 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 4, image 3 of 3
      • Remove all 16 size 3.5 mm screws with a PH1 screwdriver and pry the CD drive in order reveal one last screw that must be removed.
      Ask FixBot
    5. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 5, image 1 of 1
      • Utilizing either a plastic or metal opening tool, begin prying the case from the laptop. Lastly, remove the remaining clips located on the back of the laptop.
      Ask FixBot
    6. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 6, image 1 of 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 6, image 2 of 2
      • Once the laptop is fully open locate the cooling fan.
      Ask FixBot
    7. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 7, image 1 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 7, image 2 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Utilizing a PH00 Screwdriver remove the two 3.5 mm screws detaining the cooling fan. Then use tweezers to remove the plug connecting the cooling fan to the mother board. Lastly remove the cooling fan.
      Ask FixBot
5 other people completed this guide.
John Carlo Barajas
229 Reputation
1 Guide authored
Gateway, Team S1-G2, Luster Fall 2018 Member of Gateway, Team S1-G2, Luster Fall 2018
GCC-LUSTER-F18S1G2
4 Members
48 Guides authored
1 Guide Comment
very detailed. Thanks!
mrobinson29 - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 69
All Time: 1,785
