HP Pavilion N3350 Screen Assembly Replacement
    1. HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: step 1, image 1 of 2 HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: step 1, image 2 of 2
      • Open your laptop. Beneath the screen, there is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
      • To remove this, pry it open with a spudger tool gently. It should pop out of place.
      Ask FixBot
    2. HP Pavilion N3350 Screen Assembly Replacement: step 2, image 1 of 2 HP Pavilion N3350 Screen Assembly Replacement: step 2, image 2 of 2
      • Gently use a spudger tool or your fingers to disconnect the LCD cable from the screen.
      • This is one of three connectors that needs to be undone to disconnect the screen from the laptop.
      Ask FixBot
    3. HP Pavilion N3350 Screen Assembly Replacement: step 3, image 1 of 3 HP Pavilion N3350 Screen Assembly Replacement: step 3, image 2 of 3 HP Pavilion N3350 Screen Assembly Replacement: step 3, image 3 of 3
      • Remove the 1 cm screw with a Phillips #1 screwdriver to allow the screen and top of the laptop to be separated from the keyboard and bottom.
      • Lift the entire top away from the bottom, and set bottom half of the laptop aside.
      Ask FixBot
    4. HP Pavilion N3350 Screen Assembly Replacement: step 4, image 1 of 3 HP Pavilion N3350 Screen Assembly Replacement: step 4, image 2 of 3 HP Pavilion N3350 Screen Assembly Replacement: step 4, image 3 of 3
      • Remove the 6 rubber screw caps with a metal spudger.
      • After removing the 6 rubber screw caps, use a Phillips #1 screwdriver to unscrew the six 6mm screws.
      Ask FixBot
    5. HP Pavilion N3350 Screen Assembly Replacement: step 5, image 1 of 2 HP Pavilion N3350 Screen Assembly Replacement: step 5, image 2 of 2
      • To separate the plastic cover, use a plastic opening tool to undo each plastic connecting clip between the two.
      • You can find the plastic connecting clips by sliding the plastic opening tool along the seam between the two plastic covers.
      • Remove the top plastic cover once all connections have been released.
      Ask FixBot
    6. HP Pavilion N3350 Screen Assembly Replacement: step 6, image 1 of 3 HP Pavilion N3350 Screen Assembly Replacement: step 6, image 2 of 3 HP Pavilion N3350 Screen Assembly Replacement: step 6, image 3 of 3
      • Disconnect the connectors using a plastic opening tool.
      • Once these two connectors are released, the screen should be electronically freed from the rest of the laptop.
      Ask FixBot
    7. HP Pavilion N3350 Screen Assembly Replacement: step 7, image 1 of 1
      • At each corner, there is a 1 centimeter silver screw connecting the screen frame to the laptop. Remove these using a Phillips #1 Screwdriver.
      Ask FixBot
    8. HP Pavilion N3350 Screen Assembly Replacement: step 8, image 1 of 3 HP Pavilion N3350 Screen Assembly Replacement: step 8, image 2 of 3 HP Pavilion N3350 Screen Assembly Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • There should be thin piece of copper 'tape' holding the LCD cable down. Remove this gently with tweezers.
      • Remove the screen from the device.
      Ask FixBot
Emily Hatstat
481 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 59
All Time: 691
