HP Pavilion N3350 Optical Drive Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
70
All Time:
686
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your optical drive is not reading anything inserted, or is malfunctioning, it is possible that it is dirty or damaged due to electrical or physical circumstances. Once new optical drives are purchased, follow this guide to replace them.
Tools
    1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: step 1, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement, Keyboard: step 1, image 2 of 2
      • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
      • To remove this, pry it open with a spudger tool gently. It should pop out of place.
      Ask FixBot
    2. HP Pavilion N3350 Optical Drive Replacement: step 2, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 2, image 2 of 2
      • Remove the three 6mm screws using a Phillips #1 screwdriver.
      • Once the screws are removed, the keyboard is free from the base of the laptop.
      Ask FixBot
    3. HP Pavilion N3350 Optical Drive Replacement: step 3, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 3, image 2 of 2
      • Disconnect the green ribbon cable using a plastic opening tool.
      Ask FixBot
    1. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: step 4, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement, Optical Drives: step 4, image 2 of 2
      • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
      • Remove the top plastic covering from the base of the device.
      Ask FixBot
    2. HP Pavilion N3350 Optical Drive Replacement: step 5, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 5, image 2 of 2
      • Use a plastic opening tool to disconnect both cable connectors gently.
      Ask FixBot
    3. HP Pavilion N3350 Optical Drive Replacement: step 6, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 6, image 2 of 2
      • Once these cables are disconnected, the optical drives can be found inside.
      • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
      Ask FixBot
    4. HP Pavilion N3350 Optical Drive Replacement: step 7, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 7, image 2 of 2
      • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
      • Once freed, the CD/DVD combo drive should slide out and remove easily.
      Ask FixBot
    5. HP Pavilion N3350 Optical Drive Replacement: step 8, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 8, image 2 of 2
      • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
      • Remove the floppy disc drive from the device.
      Ask FixBot
Lyndon Davis
124 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 70
All Time: 686
